Reply 40 of 68, by jakethompson1
- Oldbie
douglar wrote on 2023-06-28, 14:04:I found this quote interesting: https://www.reddit.com/r/retrocomputing/comme … o_ide_adaptors/
The problem could be that the cheaper adapters just pass the commands through unchanged while the more expensive adapters bother to emulate ATA commands SATA drives are not mandated to support such as CHS commands. If a CHS-only BIOS is used to access the disk, this makes a difference.
I'm assuming the author was talking about the ubiquitous JMicron stata--pata bridges here when talking about the cheap ones. https://www.jmicron.com/products/list/17
Happen to know if there is a way using Linux hdparm or looking at the ATA IDENTIFY information, etc. whether a drive is one that doesn't support CHS access?
I assume if a drive "doesn't support CHS," that means it still supports PIO mode using LBA addresses?
You remind me that recently I tried a brand new 1TB WD drive through the JMicron converter, and it didn't work. I figured it was different revisions of SATA but maybe this is actually the issue. I went to my old standby drive (Toshiba HDWD110) and it worked just fine.
