First post, by Locutus
Hello there.
I bought this XT board out of curiosity (don't have any of those...).
Described as:
"The board POSTS but there is a burned trace between the 2 bottom slots.
Also I've plugged a piezo speaker to the SPK header and I couldn't hear any beeps so I don't know if there's a problem with the speaker connector or not."
Repaired burned trace (+12V probably shorted to ground on last ISA port, and replaced transistor with broken pin).
The seller checked it with CGA, but I don't have one and would prefer to use it with VGA 😉
I've tried it with:
- 100% working VGA (PARADISE PVGA1A-JK 8bit)
- Hercules (not sure if it is OK - don't have such monitor)
- EGA (not sure if it is OK - don't have such monitor)
no matter what I set on "MONITOR SELECTION SW1/5, SW1/6" with all my cards I get :
1 long, 2 short beeps - "Display adapter problem (MDA, CGA) ".
https://theretroweb.com/motherboards/s/ ... lden-turbo
The attachment XT_GOLDEN_TURBO.jpg is no longer available
Ideas highly appreciated 😉
Reply 1 of 8, by BitWrangler
Looks like it's trying to go to boot device there in the pic with the VGA board on, if it's beeping like that it might just be a no monitor connected warning, so anything come on screen if you plug one in?
Reply 2 of 8, by Horun
I see an issue if trying a VGA card as in the picture, Sw5 and Sw6 need be both off for none, only set those for MDA or CGA. Also Sw7 appears to be in a middle position which could cause some logic issues....
Reply 3 of 8, by jakethompson1
IIRC the video type switches are irrelevant if you have EGA/VGA because the EGA/VGA BIOS runs before those switches are even considered and takes care of hooking Int 10h
Reply 4 of 8, by Horun
You may be correct jake on some boards but my two XT's gives errors with a VGA if not set to none, as the main bios appears to use those to set the video before passing to any add-on roms, like a ega/vga.
I wouldn't have mentioned it but OP does not even have a monitor connected in the picture so who know what the screen would show 😀
Reply 5 of 8, by Locutus
My bad.... I took the picture with monitor disconnected... 😒
The problem is, the VGA does not initialize and there is nothing on the monitor - no matter what I set on SW 5/6 (yes - monitor cable is connected 😉).
I only have two VGAs that work on 8bit ISA - Pardise and and OTI077 (same behavior).
Reply 6 of 8, by Locutus
If anyone had a similar problem...
It turned out, that the problem was too old BIOS (v2.01).
After replacing it with v3.1 VGA works without any problem.
Reply 7 of 8, by Horun
Great ! never thought it could be a video bios issue. where did you find v3.1 ?
