On average, I see 1 to 2 PS5 consoles a week for any reason. Rarely see 3 a week.
I do have local Canada Computers but this sells strictly computer parts, computers and consumer stuff, not the commercial tools.
I'm familiar with Ackland Grainger because back in the day, I went there for special tools occasionally. Their focus is on commercial daily stuff but does not have these tools for the production line tools.
The production tools is so narrow focus on tools for securing parts together efficiently in least time and less manual involvements with loose fasteners. Just plant the suspended power tool in the device for pick'n pull a screw, in one motion "thwack" on the parts and grind the screw in.
I needed the durability of the power driver. The ones like from Dewalt power screwdriver is not made for the heavy grind in and out daily and had already issues before. The carpenter's power tools for wood and drywall is too powerful and high rpm, very high torque and is not suitable for this. The consumer electronics stuff only can take low rpm and precision low torque to loosen and tighten them without damage.
How PS5 is put together is odd.
The PS5 metal plates halves are pressed shapes that have heatsinks on both sides that sandwiches the motherboard, in which held together with metal screws that is about 45 in total after removing the plastic shells.
Earlier PS5 had a aluminum plate that completely covers one ribbon connector release that is connected to the front panel with USB ports and buttons. If that ribbon cable is not released, cannot lift the motherboard out. Later version of PS5 had small steel plate covering this ribbon cable. This was put in use after 2 years of PS5 production along with smaller motherboard.
This also hides two final screws for the APU clamp.
Hence need to remove all 45 screws to let me to release this. These screws takes torque to undo and do them even loosened.
This has two requirements: Clean heatsinks and re-spread the liquid metal on both heatsink and APU's silicon die, that got dry spot after time and sometimes have to replace soldered in HDMI port connector.
The liqid metal's dry layer between heatsink and APU die happens after about 1 year of use or less.
Attention to anyone who wants to disassemble PS5 console:
Ribbon cables release for optical drive, (important! Pay attention how to release this).
https://youtu.be/weOCONceK4E?t=250
Imagine taking out 45 metal screws:
The screws needed removed, and upper metal plate to access the PS5 motherboard.
https://youtu.be/weOCONceK4E?t=444
Cheers,
Great Northern aka Canada.
