First post, by RetroBard
I have a SB Vibra 16 PnP sound card in my 286 PC running DOS 5.0. I’m using the Unisound driver for the card. While sound is working correctly, any of the gameport controllers that I have (Gravis Analog Pro, Saitek P120) aren’t detected by any of the games or joystick testing utilities.
I’ve set the joystick port to be 200 in the autoexec.bat and I know both controllers to be working in other systems. Below is how the sound card driver reports during boot:
boot.jpg?rlkey=43zlcz14ee5ef4yot9gvh98qr&raw=1
Anything else I could try to get the joystick working, besides getting a non PnP sound card?
Reply 1 of 10, by dominusprog
Is there any rust on the metallic parts? Remove the card and check the pins for connectivity with a multimeter or use a LED and the battery holder.
OPTi MAD16 / Creative Vibra16XV ❇ 8.4GiB Quantum Fireball ❇ Win95 OSR2 Plus!
Reply 2 of 10, by RetroBard
dominusprog wrote on 2023-08-08, 15:03:
The card is visually fine. The axes and buttons on the port test all right for connectivity.
Reply 3 of 10, by dominusprog
Okay then, try the Creative drivers. I put the link for both Vibra16 and Vibra16 Value. Also check if the joystick connector goes all the way in.
Vibra16 floppy image
https://archive.org/download/creative-labs-vi … nstallation.img
Vibra16 Value
http://vogonsdrivers.com/getfile.php?fileid=1002&menustate=0
Look for the CTCM folder
Reply 4 of 10, by RetroBard
I think I already tried the first driver and couldn’t get the card working as the driver didn’t detect the card. The latter seems to be a Win95 driver. I’m running Dos 5.0 on a 286.
The connector sits in snugly. I had to sand down the outer rim of the Gravis connector down a bit, as it was a millimeter further than the pins, but even that now plugs in properly.
Reply 5 of 10, by dominusprog
Have you tried without starting the Unisound driver? Or a different joystick? How about your I/O card, does it have a connector for the gamepad?
Reply 6 of 10, by RetroBard
Yes, yes, and no I/O card with a joyport.
Reply 7 of 10, by dominusprog
Well, I'm sorry I couldn't help. Try a different card in the future.
Reply 8 of 10, by Rwolf
I seem to recall the default joystick IO port address is 201. Maybe the programs you use to test the port do not look at the BLASTER settings?
Also some Soundblasters have a Joystick Enable jumper that needs to be closed, but maybe not your PNP version?
Reply 9 of 10, by RetroBard
dominusprog wrote on 2023-08-09, 17:41:
Hey, sorry for coming out as blunt. Any help is greatly appreciated.
Reply 10 of 10, by RetroBard
Rwolf wrote on 2023-08-09, 18:15:
Changing the joystick port address to 201 did the trick! My Gravis Analog Pro is recognized now and can use it in games.
Thank you everyone for helping me to troubleshoot this issue!
