First post, by sonicam
Hi, I'm new to DosBox and just downloaded since I wanted to reinstall Duke 3D: Atomic Edition and learned that it's not supported by Windows 2000. I can't even fully install the program as it gets stuck at 99% or earlier. I also learned that DosBox would enable me to play it. I was wondering, would it be possible to initiate the Install application with DosBox and would I be able to play the game from the CD itself (if installation fails again) with DosBox? I really don't know what do to... 😦 Thanx.
Reply 1 of 7, by eL_PuSHeR
Read the fine manual.
But for starters, you need to mount a hd drive (install to) and a cd drive (install from).
Create some folder like dosgames (no more than 8 characters long) using Windows Explorer.
Then, inside DOSBox:
mount c c:\dosgames
mount d <letter of your real cd drive>:\ -t cdrom
E.g. mount d f:\ -t cdrom
d:
install (or whatever)
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 2 of 7, by sonicam
Thanx a lot. I seemed to have gotten the Install file to work on DOSBox. Unfortunately, it seems to be stuck at 4% now... 😒 but it went through, thanx.
Reply 4 of 7, by sonicam
It doesn't seem to be running at all. 🙁 but I will try this Windows port now, thanx!!!
Reply 5 of 7, by franpa
that windows port = awesomo!
AMD Ryzen 3700X | ASUS Crosshair Hero VIII (WiFi) | 16GB DDR4 3600MHz RAM | MSI Geforce 1070Ti 8GB | Windows 10 Pro x64.
my website
Reply 6 of 7, by ZWarrior
That's all well in good, but it wants the .grp file from the game. I am stuck with the acursed Plutonium Pak and can't get an update to work so I can get the updated .grp file.
It shows me the text about how if this fails that I will need to delete the install etc, and to press any key to begin.
Then it says "Bad Command of Filename" and says the patch failed. I remember the problem from years ago, but not the solution.
Reply 7 of 7, by leileilol
3drealms.com has a patcher fix on their site.
FUCK "AI"
