SFF G41/ICH7 Win9x build
First post, by marxveix
I have one SFF Fujitsu E3521E G41/ICH7 (D3041-A motherboard) and Windows 98 SE does not work well after first restart from clean install, only safe mode works, Win98SE also has no CD/DVD available, i have used 1x1GB DDR3 or 2x1GB DDR3 (2GB ram patching, 1GB works without).
https://support.ts.fujitsu.com/IndexDownload. … 92-4C7500F0F0E4
Win98SE CONFIGMG error @ normal mode:
While Initializing device CONFIGMG: Windows Protection Error. You need to restart your computer.
Is something up with standard ide controller @ Win98SE? What chipset drivers should i use?
https://www-windows98-xf-cz.translate.goog/?_ … &_x_tr_pto=wapp
Should i have G41 motherboard with ide, this Fujitsu has only sata connectors for hdd/odd.
Is there any good low profile PCI audio cards for Win9x? Low profile pciex16 graphics i find.
Low profile Nvidia Quadro NVS285 (NV44) or similar i can get for good price or totally free.
WinME works better at the moment, normal mode starts all the time and CD/DVD is available + USB also works out of the box. Realtek 8111DL lan drivers should be available for Win98SE/ME (version 5.708) and 2xPCI is better than 1xPCI and it has FDD.
Best ATi Rage3 drivers for 3DCIF / Direct3D / OpenGL / GLUT / DVD : ATi RagePro drivers and software
33+MiniGL / OpenGL Win 9x dll files for all ATi-Rage3 based cards : ATi RagePro OpenGL files
Reply 1 of 6, by The Serpent Rider
Good low profile PCIe with Win9x drivers? Radeon X550/X700 with 128-bit bus, also OEM cards like Dell - Dell E-G012-05-2436 Ati Radeon X600
GeForce cards past GeForce FX are somewhat sketchy when it come to driver bugs and I can't recall any LP models which had 128-bit memory bus.
Depends on what you consider good. If you want hardware 3D audio, you're probably out of luck. There are community projects in the works like Aureal + Yamaha sound card which has low profile option though.
Reply 2 of 6, by marxveix
ATi X600 (128bit) low profile would be good graphics card, i have X600, X700 and X800, but regular size only.
For the sound card i have no special requirements at first, at least it should work. CMI8738 has low profile ones.
https://www.farnell.com/datasheets/1671866.pdf
Better to use Windows ME with that machine then? WinME needs some tweaking for the dos part as i remember.
Reply 3 of 6, by The Serpent Rider
Nah, just install Windows 98 SE with some community patches.
Reply 4 of 6, by marxveix
The Serpent Rider wrote on 2023-08-13, 03:07:
What patches? I can get Windows 98 SE work only in safe mode right now and normal mode only starts once, right after clean install, even if i do not make any changes and i restart / shutdown that pc, only safe mode works after and i get Win98 configmg error at next boot @ normal mode.
Reply 5 of 6, by The Serpent Rider
RLoew Windows 98 patches and other small fixes like Nvidia 512Mb VRAM fix.
Reply 6 of 6, by marxveix
The Serpent Rider wrote on 2023-08-14, 08:17:
I have no other cards installed for now, just 1x1GB or 2x1GB ram, pentium e5700 and integrated graphics @ 16 colors for now, ram patch does not fix configmg, for 2GB it helps. Same goes for RLoew sata patch, configmg error still there.
