First post, by Mark_F
Ok im having trouble getting Monkey island & 2 to run properly.
I can get them running no problem, though the picture is in B&W and dont know if its something in the config...
The pack is labelled as win 95
im running XP pro SP2
CPU= AMD athlon 2300
Mem= 512 Mb
Graphics card= Radeon 9800 pro
Dont know what my motherboard is sorry, or sound card as its built into the motherboard...
As said the games run ok, just in black and white, and tbh it looks awful...
Any help will be greatly appreciated 😀
Oh and its dosbox .63...
Reply 1 of 10, by wd
Rank DOSBox Author
DOSBox Author
Maybe post how exactly you run it.....
Reply 2 of 10, by Mark_F
In what way?
I copied the cd into the dosbox c:\ drive, run dosbox, open the directory for the game and run the exe file, as said everything seems ok bar the colour settings (ie its black and white) other than that everything else seems normal
Reply 3 of 10, by wd
Rank DOSBox Author
DOSBox Author
1) don't use ancient dosbox versions, use 0.72
2) post EXACTLY how you mount and start the game
Reply 4 of 10, by Mark_F
ok ill dl 0.72 and give it a try...
How you mean exactly how i mount and run the game? i never really had the hang of dos, so if you post or pm what you mean by the above ill sort 😀 ty
Reply 5 of 10, by wd
Rank DOSBox Author
DOSBox Author
Maybe read the guides on the dosbox forum.
Basically you have the game in some directory, say c:\old\mi1,
you mount that with "mount c c:\old", then you start it with
"c:" then "cd mi1" then "monkey" or something like that.
Reply 6 of 10, by Mark_F
Ok installed 0.72
On my comp i have my dos games in C:\DOS\CDRIVE (these 2 games specifically have just been copied directly from the CD and are in directories as named on the CD) so to mount as a drive i have added
mount C C:\DOS\CDRIVE
C:
to the config file (at the bottom) and have C:\> as my prompt on startup.
The path for monkey island 2 (the exe file) is as follows on my comp...
C:\DOS\CDRIVE\MONKEY2\MONKEY2.exe
So to start the game i open dosbox, type 'cd monkey2' and am left with the following prompt
C:\MONKEY2>
I then type 'MONKEY2 exe'
The game then starts, though still in black and white...
Reply 7 of 10, by wd
Rank DOSBox Author
DOSBox Author
What language is the game?
Start it with "monkey v" or "monkey e" (try "monkey ?" to see the parameters).
Reply 8 of 10, by Mark_F
It is the uk english version
All above show as illegal commands unfort (btw tyvm for going through this with me...)
Reply 9 of 10, by wd
Rank DOSBox Author
DOSBox Author
Well for monkey2 use "monkey2 e" and so on.
Reply 10 of 10, by Mark_F
'monkey2 v' works 😀 again thanks for your time 😁
now runs perfectly
