A number of the big board maker shipped their own backplate solutions for this class of boards, though Tyan doesn't seem to have been own of them 🙁
My Asus NCCH-DL & NCCH-DR boards both came with the X-PAD accessory kit, with adhesive backplates plus various heights of threaded nuts and rubber pads (these replaced the CEK springs)...
The attachment Xeon 604 CPU Support.jpg is no longer available
...and my Iwill Dh800 came with a full size backplate to be screwed to the chassis...
The attachment Iwill Xeon backplate.jpg is no longer available
You also used to be able to get similar generic solutions like this - hard to find today though...
The attachment Xeon 604 backplates.jpg is no longer available
If making your own, watch the height of the tapped threads (may have to add small threaded spacers) so as to apply sufficient load when the heatsinks are screwed fully down
