First post, by riplin
- Newbie
Hi folks,
I'm trying to get my CT3900 sound card to work on my Pentium 133Mhz system with some sane settings. Right now it only works if I set it up to use Port 220h, midi port 300h, IRQ 2, DMA 0 (yeah, weird) and DMA 6. It will refuse to work with any other settings.
In the BIOS I've tried setting PnP OS to Yes and No, reserving a bunch of resources for ISA and even disabling all COM and LPT ports. Nothing will persuade it to work on any other settings. I pulled out all other cards in the system, so now it only has a sound card, Promise IDE card and S3 Virge video card.
Another weird thing that happens is, if I force initialize the sound card with regular settings (irq 5, dma 1 and 5) then CuteMouse will freeze on init with a PS/2 mouse attached.
One thing I did do was replace the Dallas RTC with one of those replacement boards with a removable battery. I take it that's not going to have an effect on this? It replaces a Dallas DS12887A, which should be compatible.
Specs are:
ASUS P/I-P55TP4XE Bios version (downloaded from retro web): 12/30/97-82430FX-PI-5XTP4C-00
Intel Pentium 133Mhz
128MB memory
Promise Ultra133 tx2
S3 Virge/VX 8MB
Any hints / tips greatly appreciated.
There's a MR BIOS available for this board. Would switching over to that help?
