Reply 40 of 203, by N O V A TV
ZellSF wrote on 2023-08-25, 09:58:On the subject of Arcturus; you haven't reconsidering adding any hacks to make resolution forcing work better for some games, Dege?
DDrawCompat has some tweak-able hacks that allows for fixing some games that have issues in dgVoodoo with resolution forcing, for example the lines because of tiling issues in Arcturus's text boxes (though Arcturus looks sort of bad at times with DDrawCompat because of no way to force 24-bit zbuffer).
There's a sprite detection setting that can set separate clamping and filtering options based on Z coordinates.
Hello. I don't understand the above. Are you asking Mr. Dege?
Have you modded the game Arcturus yourself?
I tried to use dgvoodoo together by trying the rudimentary modding.
Only the required dgvoodoo files are simply included. (Based on latest version)
I don't have detailed knowledge of VGA 3D.
