Reply 25081 of 31608, by debs3759
gmaverick2k wrote on 2023-08-28, 19:04:
Does anyone know where I can dump images of the reload cd and the recovery diskette?
http://www.vogonsdrivers.com/ works as well. It's worth uploading to both. I personally don't always find things easily on archive.org
Reply 25082 of 31608, by gmaverick2k
debs3759 wrote on 2023-08-28, 21:17:
Thanks I will try this. Archive.org can't search for what I've uploaded.
On a side note after restoring image and installing ct4700 driver from overclockersuk forum thread and hearing ctmelody (1997) startup chime brought me right back 😀 haven't heard this since two decades ago..
Love the ensoniq mixer. Installed full fat version of ati rage 128 pro agp4x with vivo(?) as demoed by Phil's computer labs, ati multimedia centre works as I remember : 😁
Athlon xp 2800+ removes all bottleneck and is cooled with silent noctua. Quiet, snappy sand stable
"What's all this racket going on up here, son? You watchin' yer girl cartoons again?"
Main:z440/2699v3/RTX3060Ti/iFiZenDAC/T480 IPS
98:KT333/AthlonXp 2500+Barton/V3 3000/Vortex2/SC-55
DOS:SS7/P166MMX/V3 2000/PicoGus
XP:Edge72/3570K/GTX970/X-FiTi
Reply 25083 of 31608, by Ensign Nemo
I love Vogons, but it's always good to have a backup option. The Internet Archive is a mainstream project and should be able to secure funding for awhile. Then again, being more mainstream can have a downside and they could decide to change their policy on hosting certain types of software. Like all types of backups, it helps to have more than one.
Reply 25084 of 31608, by debs3759
That's why I suggested both 😀 Any site could just disappear at some point, the more copies are on different sites, the better the chance of it still being available in 5 or 10 years 😀
Reply 25086 of 31608, by gmaverick2k
Ensign Nemo wrote on 2023-08-28, 22:08:
can't login to upload using vogons username/password. cant find link to register either on the vogonsdrivers website..
Reply 25087 of 31608, by BetaC
Today I got my Macintosh Clone set back up because the DOS games I was thinking about playing all kind of fell by the wayside as I got back in to a modern game. At the same time, I'm prepping for potentially finding something of note in the next few days, as I will stop by the free geek in the Twin Cities.
Reply 25088 of 31608, by PD2JK
Recapped a Medion 9901 board.
The attachment DSC_5947.JPG is no longer available
The attachment DSC_5950.JPG is no longer available
Now that it's working, I might add the ISA slot. But that requires some extra components I guess. Anyone who might know the original MSI (?) board with ISA?
has all kinds of stuff
Reply 25089 of 31608, by PD2JK
The attachment DSC_5951.JPG is no longer available
I figured one could mount a Noctua fan like this as well. Surprisingly sturdy.
Reply 25090 of 31608, by arnovdheiden
Received a 12ns tag ram and installed it in my asus t2p4 in order to cache 512mb. Set the according jumper.
Reply 25091 of 31608, by debs3759
gmaverick2k wrote on 2023-08-29, 06:13:
You need to message @SquallStrife to set up a login account.
Reply 25092 of 31608, by Turbo ->
Shponglefan wrote on 2023-08-29, 00:27:
Re-capped a Gigabyte GA-586ATV motherboard. Also replaced a damaged IDE connector.
You have a nice set of equipment in your workshop. What is the model name of that Panavise PCB holder?
Reply 25093 of 31608, by Shponglefan
Turbo -> wrote on 2023-08-29, 19:28:
Thank you!
The PCB holder itself is the Panavise Model 315 Circuit Board Holder. The base is a combination of the 300 Vise Base and 312 Base Mount.
Pentium 4 Multi-OS Build
486 DX-33 with 5 sound cards
Reply 25094 of 31608, by Windows9566
PD2JK wrote on 2023-08-29, 11:25:
Recapped a Medion 9901 board. […]
i need to do the same with my ABit KT7A, it currently does post but there are like 5 bulging Teapo brand capacitors on it and i won't be using it like that.
Toshiba Satellite 200CDS
Toshiba Satellite Pro 430CDT
Toshiba Satellite Pro 480CDT
Toshiba Tecra 740CDT
IBM Thinkpad 760LD
Nan Tan(Clev0) FMA86T
Reply 25095 of 31608, by gmaverick2k
Finally got round to installing windows xp on z87-g45 gaming motherboard I had laying around for over a year. It has a 4770k installed in it. I think I gave up because of ahci issues. Stuck in a spare Asus mini gtx 970. After downloading various copies of xp and slipstreaming ahci drivers I finally cracked it. Long story short look at hardware id and match it with yada yada yada .Finally using ahci for xp, had always used ide mode.
Oh the virtual cd iodd saved a lot of time and sanity. Without it is have given up again can't be assed waiting for it to bsod or burn cd's to be coasters.
Reply 25096 of 31608, by PcBytes
Been tinkering with the P6VBX7. Finally got around and got rid of all Canicons off it - as it stands now, it's OST 1000uF 6.3v for the caps, Panasonic FJS 820uF 6.3v nearly everywhere else, aside from a KZG 470uF 16v that went on the ISA line.
Installing Win2k on it. Swapped in a Celeron 533, and if I can find the P6VBX7A BIOS for it, I suppose Coppermine P3s might work too.
Reply 25097 of 31608, by PcBytes
Well, I'm back to report I've been hit with both the most fampus and the most weirdest to fix bug on that P6VBX7.
Remember how on Virtualbox you'd encounter a race condition due to a bug in the 2k IDE driver?
Well, my board seems to be the rare case where that happens on a real hardware - setup runs well enough, but exactly a few seconds before you'd get to the components installation part (last two progeess bars - one is for that IIS component, the other is the classic component registering and saving settings) it unexpectedly closes, PC reboots and you're back to the first GUI setup screen for 2k.
Anyone has an idea how I'd tackle this 🤣? On Virtualbox I'd just adjust the delay for the IDE driver but not sure how I'd circumvent this issue on a real mobo, aside from using an Epox 3VCM to install 2k first on and then move it to the LT P6VBX7. (since they both use the same VIA drivers, more or less.)
Reply 25098 of 31608, by appiah4
PcBytes wrote on 2023-08-31, 06:47:
Well, I'm back to report I've been hit with both the most fampus and the most weirdest to fix bug on that P6VBX7. […]
Have you tried disabling ACPI? I've had boards that do this because ACPI and 2K did not play ball..
Reply 25099 of 31608, by PcBytes
appiah4 wrote on 2023-08-31, 06:48:
IIRC yes, it's disabled in the BIOS by default anyways. The issue has to do with IDE though.
Here, from Virtualbox's addressing of this issue:
Virtualbox Manual wrote:
When installing Windows 2000 guests, you might run into one of the following issues: […]
Installation reboots, usually during component registration.
Installation fills the whole hard disk with empty log files.
Installation complains about a failure installing msgina.dll.
These problems are all caused by a bug in the hard disk driver of Windows 2000. After issuing a hard disk request, there is a race condition in the Windows driver code which leads to corruption if the operation completes too fast. For example, the hardware interrupt from the IDE controller arrives too soon. With physical hardware, there is a guaranteed delay in most systems so the problem is usually hidden there. However, it should be possible to also reproduce it on physical hardware. In a virtual environment, it is possible for the operation to be done immediately, especially on very fast systems with multiple CPUs, and the interrupt is signaled sooner than on a physical system. The solution is to introduce an artificial delay before delivering such interrupts. This delay can be configured for a VM using the following command:
VBoxManage setextradata VM-name "VBoxInternal/Devices/piix3ide/0/Config/IRQDelay" 1
This sets the delay to one millisecond. In case this does not help, increase it to a value between 1 and 5 milliseconds. Please note that this slows down disk performance. After installation, you should be able to remove the key, or set it to 0.
Not sure but I suspect the SDRAM Cache Latency setting to also be the culprit here. Interesting how nobody encountered this on a physical machine and I'm probably the first to do so.
