Reply 120 of 171, by Joseph_Joestar
- l33t++
Meatball wrote on 2023-08-30, 23:31:During installation, the game presents a message stating a "Voodoo 2" has been detected, and states to make sure Glide v3 drivers are installed (which they are) ... However, that's as far as I can get. Patch 1.1 is installed. If the game doesn't lock up my system immediately, it does so as soon as I try to pick any option from the main menu.
Ouch. In my case, Test Drive 5 doesn't detect the Glide capabilities of my Voodoo 3 during installation, and merely sees it as a Direct3D card. The game works fine in that mode, but if I try to manually switch to Glide (by using the aptly named Voodoo2.exe) everything becomes unstable. It does start, and I can get into a race, but the game crashes if I try to go back to the main menu.
That's why I thought it might be better for someone with an actual Voodoo 2 to test it. Very odd that it doesn't like your Obsidian card either. AFAIK, that's basically a Voodoo 2 SLI on a single board.
