First post, by naujoks
I have a Pentium II/III board with an i440EX chipset that's stuck at the boot screen.
It doesn't recognise the PIII CPUs as such. I have one PIII 500MHz, which registers as a PII MMX 333MHz, and a PIII 550MHz, with which the board doesn't post at all.
I bought the board and PIII 550MHz CPU together and the seller said that it was working until he put it in storage. I wonder if this can be true though, as the BIOS date is from 1998 and the PIII came out in 1999.
Do we think the board could work with a Pentium II CPU?
There's several jumpers on the board to set the FSB. It's currently set to 66MHz (83MHz being the max. that can be selected), the multiplier is jumpered to auto (I played around with but jumpers, but it didn't make the board boot).
There's absolutely no indication who the manufacturer of the board is. The only marking that could be a model number is 617V15, but the net is not coming up with anything, so I can't find any manual or BIOS update which might be able to make the board recognise PIII CPUs.
Ideas?
