Radeon 9600XT strange blue pixels
First post, by kalanneni
Hello all,
I bought a Radeon 9600XT to power my P4 gaming PC. Everything is working fine, except it showing blue pixels on the screen (I reckon it has problem showing some sort of colors).
I tried different types of monitors CRTs,LEDs and different outputs VGA, DVI and all showing the same blue pixels.
To my surprise, screenshots made by WinXP are perfect.
Could it be the VGA and DVI outputs?
    1.81 MiB
    84.44 KiB
    Screenshot
Win98SE PC - ASUS P3BF, PIII 500, 256 Mb RAM, V3 2000, SB Live
WinXP PC - ABIT BH7, Pentium 4 2.4, 1 GB RAM, ATI Radeon 9600XT
Reply 2 of 33, by dormcat
As a photographer, those "blue pixels" and the bright white clouds within are very similar to the typical overexposure "clipping." Could it be your output has been set to 16-235 instead of 0-255? While this setting is usually reserved for HDMI output, your symptom is way too similar to clipping at 235.
Take a look at the attached calibration chart with full-screen; where do blue pixels appear?
104.44 KiB
Somehow I have a feeling that red pixels might appear around black areas......
Reply 3 of 33, by kalanneni
dormcat wrote on 2023-09-08, 11:45:
As a photographer, those "blue pixels" and the bright white clouds within are very similar to the typical overexposure "clipping […]
Nice, I'm going to look at it, but unfortunately I store this PC in my office as a non 100% hardware. Going to reply back on Monday. 😀
What if it has this calibration problem you mentioned? I mean what could be done to amend it?
Thanks
Reply 4 of 33, by kalanneni
There it is.
    1.62 MiB
    Test Pattern
Reply 5 of 33, by The Serpent Rider
That's interesting, so apparently it completely lacks red in that specific color gradient area, so everything that have red mixed in will display color without it. Probably an obscure driver bug.
Reply 6 of 33, by dormcat
kalanneni wrote on 2023-09-11, 06:13:
There it is.
So it's not clipping but missing at or around 219 of the red channel. Never seen this kind of malfunctioning before.
Reply 8 of 33, by kalanneni
giantclam wrote on 2023-09-11, 07:05:
Done it now, but nothing changed. I'm starting to feel desperate.
Reply 9 of 33, by drosse1meyer
have you tried dialing back to a lower color depth (e.g. 16 bit)?
Reply 10 of 33, by kalanneni
drosse1meyer wrote on 2023-09-11, 12:11:
I remember trying it earlier and didn't help, but checked it now as well. It seems there are more of that "false" pixels in 16 bit.
Reply 11 of 33, by drosse1meyer
kalanneni wrote on 2023-09-11, 12:35:
Reply 12 of 33, by darry
It may be worth trsting under real mode DOS with a VESA test suite, like the one thst comes with UniVBE or possibly Scitech Display Doctor .
If the issue is present too, it would exclude the Windows driver as a culprit.
I wonder it this might be due to a custom VBIOS meant for some industrial/scientific application.
Reply 13 of 33, by giantclam
Does yours have a NTSC/PAL jumper?
edit: just thinking about this ...if the screenshot from winxp is fine, that means the framebuffer is fine .... so this problem hints at a bad RAMDAC ; trying a different monitor would be a check
Reply 14 of 33, by kalanneni
giantclam wrote on 2023-09-11, 14:07:
I tried 2 different CRTs and a LED monitor as well. Same result. 🙁
Reply 15 of 33, by darry
If it does the same thing over DVI and VGA, it is not the RAMDAC .
I am guessing that it is either a weird hardware fault OR maybe something to do with a custom VBIOS.
What brand/model is the card and can you share VBIOS dump ?
Reply 16 of 33, by kalanneni
darry wrote on 2023-09-11, 18:55:
Unfortunately I could only find this label on the card. Trying to gain VBIOS dump information on Thursday.
    1.81 MiB
    VGA
Reply 18 of 33, by kalanneni
By the way, there is an NTSC/PAL jumper, but does nothing regarding this problem. 🙁
Reply 19 of 33, by giantclam
kalanneni wrote on 2023-09-12, 12:27:
Yeah, likely only touches 'tv-out'.... I've got a jetway 9600XT.... the other thing I was thinking about, is does the 3D unit of the GPU display the same problem (in win98 we're only seeing the 2D unit output)...just curious
