First post, by UselessSoftware
I'm having a lot of weirdness trying to set multiplier jumpers on a K6-2/550 on this Soyo. I've found some conflicting information on how to properly set these CPUs.
After some trial and error, I ended up with the following configuration:
FSB: 100 MHz
Multiplier: 2.0x
And the BIOS reports 550 MHz, however when I boot Debian 8 on it, it says 525 MHz.
mike@k6-550:~$ cat /proc/cpuinfo
processor : 0
vendor_id : AuthenticAMD
cpu family : 5
model : 8
model name : AMD-K6(tm) 3D processor
stepping : 12
microcode : 0x8b
cpu MHz : 525.723
cache size : 64 KB
fdiv_bug : no
f00f_bug : no
coma_bug : no
fpu : yes
fpu_exception : yes
cpuid level : 1
wp : yes
flags : fpu vme de pse tsc msr cx8 pge mmx syscall 3dnow k6_mtrr vmmcall
bogomips : 1051.44
clflush size : 32
cache_alignment : 32
address sizes : 32 bits physical, 32 bits virtual
power management:
I was seeing the BIOS also report 550 MHz when I had the motherboard multiplier set to 5.5x, however it was extremely unstable and Linux crashed early during the boot process.
So, I guess three questions.
1. What is internally happening with the multiplier on this K6-2?
2. Why does Linux report 525 MHz instead of 550 MHz like the BIOS?
3. Is my jumper configuration currently correct? I assume so, yet I'm not sure why 2.0x100 to get 550 is correct 🤣
If anyone can shed some light on this, that'd be awesome!
Reply 1 of 8, by Repo Man11
The K6-2 550 interprets the 2x multiplier as 6x, which allows it to be run @ 400 to 500 MHz in older Socket 7 motherboards with 66 to 83 MHz frontside bus speeds. My hunch is that the motherboard can't properly display the correct speed, and this is also throwing Linux off. Your best bet is to go back to the 5.5x100 and try and sort out why it's unstable. Maybe try setting the voltage a little higher than stock. Do you have the most up to date BIOS? Retro Web shows the last BIOS is dated 11/11/99; if that's newer than what you have, I'd be sure to update it.
Reply 2 of 8, by Sphere478
My guess is you have it set to 95x5.5 and bios is guessing 550
At 2x it is probably running at 95x6
Be sure your heatsink and fan and paste are good.
Check voltage.
May have bad mobo caps
Sphere's PCB projects.
Reply 3 of 8, by UselessSoftware
Repo Man11 wrote on 2023-09-14, 02:16:
Thanks, I'd read about a 3x internal multiplier, but that only applies if the motherboard multiplier is set to 2x?
I already did try running 2.4v instead of 2.3v and it made no difference.
The BIOS is not quite the latest. The date is 7/26/1999. I may try an upgrade. I wonder if I can find a BIOS changelog for this.
I can't find the 5SSB on Retro Web. There's a 5SSM, but it looks pretty different. Google actually turns up very little about the 5SSB for me.
Sphere478 wrote on 2023-09-14, 02:52:
My guess is you have it set to 95x5.5 and bios is guessing 550 […]
Check voltage.
The jumpers are definitely set to 2x100 right now, I just double checked.
Heatsink/fan/paste is very good, I freshly installed it last night with some MX-4 and I'm using one of those heatsinks that screws down to ensure a good contact. It's nice and tight.
I'll check voltage and investigate caps after I try some other things and still have problems.
Reply 4 of 8, by Repo Man11
My mistake, you're correct I was looking at a 5SSM.
Reply 5 of 8, by Sphere478
UselessSoftware wrote on 2023-09-14, 03:18:
Thanks, I'd read about a 3x internal multiplier, but that only applies if the motherboard multiplier is set to 2x? […]
Check voltage.
See what memtest86+ or chkcpu says
Jumpers/manual may be wrong. Usually the bios rounds to the nearest best guess and software shows the actual. I could be wrong but my bet is that it actually is 525 mhz
Reply 6 of 8, by UselessSoftware
100 x 5.5x is still unstable. I even tried going up to 2.5v.
90 x 2x (so 6x internally) gives me a stable 540 MHz, reported by both the BIOS and Linux.
This thing only seems stable with the K6-2 if I use 2x multiplier. It works perfectly fine with other multipliers with other CPUs, I've used a Pentium MMX and a Cyrix MII-366 with no issue.
I had it running Server 2000 on the Pentium with this same RAM for over a week before I shut it down and no problems whatsoever. That included running some intensive games for a while that a Pentium 1 really has no business running, like Deus Ex.
I suppose memtest86 can't hurt though.
EDIT: No, actually I just had a benign/simple program (inxi) cause a kernel crash in Linux with 90x2. Not stable. Could this CPU be defective?
Reply 7 of 8, by Repo Man11
Yes, the CPU could be defective.
Reply 8 of 8, by shamino
You seem to have a stability problem which you're operating on the edge of, depending how you set the clocks.
Make sure the dividers are set correctly (so PCI is running at or close to 33MHz). If that's set wrong, PCI could be at 1/2 of FSB which would put it in the high 40s - which won't be stable.
You might also have dodgy power affecting the CPU or the chipset or the RAM (or everything). This could be caused by bad capacitors, bad power supply, or other failing components on the board.
Prime95 torture test (or mprime under linux) and memtest86 are both very good for checking stability. I like to check at least a few hours of memtest86 before installing an OS.
