First post, by Uzix
Wanna publish my small hobby project - Kharon-386. This is tiny IBM PC compatible machine with 386 CPU, integrated VGA and sound.
Tech specs:
- M6117D System-On-Chip with integrated 386SX40 (almost compatible) CPU and M1217B chipset
- 4MB RAM
- TVGA9000i VGA video
- ES1868F SoundBlasterPro-compatible sound
- SAM2695 MIDI synthesizer
- ESP8266 WiFi module
- PS/2 keyboard and mouse inputs
- 2xCOM ports
- CF card slot
- Real-time clock (RTC) with backup battery
- Integrated PC-speaker
- 5.1V microUSB power
- Two 4-layer 10x10cm PCBs + front/back panel PCB
- G738 or G706 enclosure
Project is open source and non-commercical, sources are distributed under CC-BY-SA-4.0 license.
All source files, fabrication files and other info at link:
https://github.com/UzixLS/pc-kharon-386
Reply 1 of 9, by debs3759
That's a proper cutie! I'd love something like that, but my soldering skills are not good enough 🙁
Reply 2 of 9, by zami555
Wow, looks really nice. Congratulations!
Any chance you can share some results of some benchmarks?
Have you found any issues with some software or games (you've mentioned CPU implementation is "almost compatible")?
Reply 3 of 9, by Uzix
zami555 wrote on 2023-09-19, 17:38:
Which ones are you interested in?
Yes, there is known problem with doslfn - it uses undocumented x86 opcode "setalc", which isn't supported by M6117D. I've sent patch to doslfn maintainer a few months ago.
Also I couldn't get SFX in Tyrian. I've tested it on ICOP-6025 and got same result, so I suppose this problem isn't Kharon-specific.
Reply 4 of 9, by keropi
Uzix wrote on 2023-09-19, 17:50:
Don't think too much about the Tyrian issue - it's sound engine is problematic in general and for example also has issues with CS4237 on "normal systems"...
Kudos on the project ! it looks very nice!!!!
Reply 5 of 9, by midicollector
That is supremely cool! I absolutely love it. The ESS is a great addition, too. Can't believe all the hard work you must have put into this, very impressive. I wish I could work that hard on something this cool!
Some random suggestions for future improvements: support for different processors (486, pentium), an ISA or PCI slot, upgradable ram, midi out, a usb slot, SATA for CD/HDD/etc.
Reply 7 of 9, by UselessSoftware
I'm very impressed! Clearly a lot of care and effort went into this. I'd build one if my skills were up to the task.
Reply 8 of 9, by megatron-uk
Would love to replace several of my full sized pcs with one of those, but surface mount soldering of that fine pitch is just out of my league.
https://www.target-earth.net
Reply 9 of 9, by mogwaay
Wow, amazing work! 👏 I've often pondered over making a 386/486 machine after I made an 8088 based one during lockdown, but it's quite the step up and I never got round to it. This would be super cool to build, maybe a future project if I get the time...
