Reply 50480 of 60066, by Repo Man11
- l33t
I stopped by the computer store since i was in the neighborhood. For fifteen dollars: an Audigy 1, an SB Live (but it's an SB0200) and a Quadro FX500. All three work, but the Live is pretty useless, and I don't have much use for the Quadro. But I'll find a place for the Audigy. I knew there was an SB Live that you had to look out for, but I thought I had an SB0200 that worked fine; I actually have an SB0220. I should have done a search on my phone, but so it goes.
