dosbox.conf under Linux
First post, by ionmich
I have just installed DosBox and it's running under Linux.
When I try to "config -writeconf test" no file is produced.
When I try to speed up using the F-keys nothing happens. However the ALT-ENTER does change the screen size.
I read the dosbox guides but Linux is not covered. Any help would be much appreciated. My application is running but very slowly. The CPU cycles box indicates 3000.
Thanks
Reply 1 of 7, by wd
Rank DOSBox Author
DOSBox Author
Works fine here.
Reply 2 of 7, by bugs_bugger
Maybe you need to create the file test first, do touch test on your console.
Reply 3 of 7, by MiniMax
Rank Moderator
Moderator
touch'ing should not be necessary. ionmich is probably looking for the file in the wrong place.
Try this before write-conf'ing:
mount X "."
X:
dir test
dir test
dir
Is the file there?
_________________
Reply 4 of 7, by Qbix
Rank DOSBox Author
DOSBox Author
nah won't work
dosbox writes when no file is given in to your current working directory.
so try
config -writeconf /tmp/test.conf
Water flows down the stream
Reply 5 of 7, by MiniMax
Rank Moderator
Moderator
Well Qbix - that is why I asked to have "." mounted as X 😀
_________________
Reply 6 of 7, by wd
Rank DOSBox Author
DOSBox Author
Yeh and if he's using dosbox 0.58 both things won't work. Same for some
hardened textmode close-but-not-yet-linux.
Reply 7 of 7, by ionmich
Thanks everyone. I found it in my Linux home directory. I wasn't looking very logically. Working on the speed problem now. I am sure I will have more questions later.
