First post, by jbb_bloody
Hey there,
i have found a similar thread for the Compaq Deskpro 20 PIN ATX Power Supply, but nothing related to the i would assume PRE ATX so AT Powersupply Pin-Out.
I do own a Compaq Deskpro 4000 5200MMX but it has a completly different connector, which reselbles more of an ATX Style connector. From what could read on
the internet this can be found on the pre MMX Versions and on the Pentium Pro Version (this is what this is)
The attachment Compaq Deskpro Power Supply PINS.png is no longer available
Any hint, pointing into the right direction, or anyrhing else might be helpful!
I would be happy to buy a powersupply or attempt to mod one to match the requirements, so anything might be helpfull.
THANK YOU!
Kind Regards
Tim
Reply 1 of 2, by PC Hoarder Patrol
jbb_bloody wrote on 2023-09-23, 19:37:
Hey there, […]
Hey there,
i have found a similar thread for the Compaq Deskpro 20 PIN ATX Power Supply, but northing related to the i would assume PRE ATX so AT Powersupply Pin-Out.
THANK YOU!
Kind Regards
Tim
Welcome to Vogons 😀
Far as I can tell from Compaqs own quick reference guide for the Deskpro 4000 ( https://web.archive.org/web/19961226054213/ht … me2/dp4000.html ) there were two power supply options...160W (part no. 247132-001 ) and 200W (part no. 247134-001 )
Seems like these are still available online (here's a 200W one in the UK - https://www.solentspares.com/en/pc/4217-compa … 5965616161.html )
Reply 2 of 2, by jbb_bloody
This is excactly what i was hoping for, thank you very much! Going to order this!
