First post, by tinnov
I found this motherboard in a scrap bin, and it's in generally good condition with two caveats... First, it has a botched RTC removal attempt. It doesn't look too bad and I can fix that up no problem (will add a proper socket). Second, it's been completely stripped of everything that could be removed; not even a single jumper remains... Including the BIOS chip. Now I'm sure I can find a blank replacement BIOS chip, but finding the right BIOS image to load onto it may be tricky... But that's putting the cart before the horse. Can anyone here help me identify the board, so I can save it??
