Reply 25380 of 31622, by appiah4
stef80 wrote on 2023-09-25, 07:50:
I took the package with all PLCC adapters. It works great. Erasing/blanking/flashing is unusually fast comparing to regular motherboard flash from floppy 😀.
Unfortunately, it's not supported via "minipro" on Linux., unlike older TL866A, CS or II Pro.
TL866II Pro is the only one supported by both: latest XGecu software and minipro.
OK, minipro you say.. And here I was using Xgpro under WINE the whole time, I'm an idiot 🤦
Reply 25381 of 31622, by stef80
Eh, didn't test Wine setup 😀.
Reply 25382 of 31622, by dominusprog
Cyrix 6x86 150+ @120MHz. This is the first working Cyrix processor I've purchased.
The attachment CYRIX_2390.JPG is no longer available
I have a question. NSSI reports the name as random ASCI characters, is this normal?
The attachment NSSI_SCREENSHOT.JPG is no longer available
OPTi MAD16 / Creative Vibra16XV ❇ 8.4GiB Quantum Fireball ❇ Win95 OSR2 Plus!
Reply 25383 of 31622, by bearking
Woow! That was the cpu in the first system I've built! So it was my first ever cpu 😀
Reply 25384 of 31622, by bakemono
Tried to overclock my 6MHz AT to 10MHz. It was already at 8MHz, and I had tried 10MHz once before with the result being a system that booted but froze after a minute. But now I have a few 68-pin PLCC sockets and I heard about putting a PLCC 286 into a socket and plugging that into a PGA 286 socket. I thought I had a 10MHz PLCC 286 in a drawer somewhere. It turned out to be an 8MHz part, but that is still likely to do better than a 6MHz one. So I put it in.
It boots at 10MHz, but with only 512KB of RAM. The memory on the Basic Time AT 4x4 Plus expansion card is no longer recognized. Some of the DRAM chips were 150ns, and I found 120ns ones to replace them with but it still wasn't enough. The Checkit 3.0 memory test showed no problems in the base 512KB, but if I keyed in the address ranges for the expansion memory (512KB to 640KB and 1.0MB to 1.875MB) it came up with a lot of errors. Guess I'll have to stick with 8MHz for now.
Wreckage reimagined on itch: https://90soft90.itch.io/wreckage-dash
Reply 25385 of 31622, by nhattu1986
I'm playing with the VS440FX system, trying to install windows 98 and get the dvd-ram/pd drive to work with windows 98, and it is not the best experience in the world.
The panasonic driver work, but it won't play nice with external usb device, it will hang the system when I open the explorer until the driver was removed.
Nero inCD work fine, but sometime the system lock up for no reason.
and dvd-ram write speed is super duper slow.....
no wonder nobody want to use dvd-ram at all.
The attachment 23-09-23 18-06-31 1385.jpg is no longer available
Reply 25386 of 31622, by Siran
Finished Wing Commander: Privateer - Righteous Fire on my 486. Only played the main game as a kid.
Reply 25387 of 31622, by Shponglefan
Probed the faulty Roland SCC-1 with my oscilloscope today.
I confirmed the DAC appears to be getting a clock and digital input signals, but generating no output.
I'm going to do some further testing on voltages. Unless anything else jumps out, I may just replace the DAC and see if that fixes this card.
The attachment Roland SCC-1 test bench.jpg is no longer available
The attachment SCC-1 data signal.jpg is no longer available
Pentium 4 Multi-OS Build
486 DX-33 with 5 sound cards
Reply 25388 of 31622, by BetaC
Posting about this now because it took me a week to get things going mostly right. I even replaced terrible old fans in the case and power supply with Noctua ones.
The attachment vgnF.jpg is no longer available
Yeah, I've been working inside my new-to-me Power Computing mac clone. One of those clones from the company that was getting new PowerPC processors before Apple, and got bought out at the end of the program as well. Still going to replace the not-working SCSI CD drive.
The attachment vgnC.jpg is no longer available
The thing is, it's also got something special inside it.
The attachment os.jpg is no longer available
I got incredibly lucky, and got a Newertech G3 inside it as well. Combine that with the 320MB of 168 Pin EDO inside, and I have a mostly good machine.
Reply 25389 of 31622, by Babasha
Made an some silly Win 3.1 modification by the motives of Motif Unix window manager 😀
- partial LFN support
- FAT32 defrag
- file managers
- program manager replacement
- shrink it and make more DOS 7.1 compatible
Need help? Begin with photo and model of your hardware 😉
Reply 25390 of 31622, by Kahenraz
Babasha wrote on 2023-09-26, 06:20:
Made an some silly Win 3.1 modification by the motives of Motif Unix window manager :)D
Try PC Tools 2.0 for Windows, which includes Central Point Desktop. It is by far my absolute favorite graphical shell for Windows 3.1. The only downside is that there is no LFN support.
http://toastytech.com/guis/cpdesk.html
The attachment cpdeskmain.png is no longer available
The attachment cpdeskgroups.png is no longer available
Reply 25391 of 31622, by Babasha
Kahenraz wrote on 2023-09-26, 06:57:
Try PC Tools 2.0 for Windows, which includes Central Point Desktop. It is by far my absolute favorite graphical shell for Window […]
Tnx! I know it from the mid of 90’s but it not my fovourite)))
Reply 25392 of 31622, by mrfusion92
Unlocked 1024x768 in GLQuake. Now my ultimate Win98 build is finally complete with a PIII-S, FX 5200 Ultra and the Voodoo2 SLI.
The attachment Screenshot 2023-09-26 12-53-12.png is no longer available
The attachment PXL_20230926_104258720.jpg is no longer available
The attachment PXL_20230926_104542094.jpg is no longer available
Reply 25393 of 31622, by Tiido
Yesterday I broke my Nokia 445ZA out of the limits of its EDID EEPROM, by making an utility to produce a new one that exposes all it can do not just "1600x1200@85Hz". I will do this with all my VGA devices eventually.
I did a mod to move its EDID EEPROM to the neckboard for easy access, in case I needed some tweaks, since the original location is on the mainboard and in front where it is absolutely inaccessible and everything must be dismantled... and it was a good call as I had to change EDID version from 1.4 to 1.3 or WinME wasn't gonna play along and not recognize the monitor. This is why newer monitors will just be "default monitor" with limited capability since they advertise EDID 1.4.
I also repurposed the useless Serial Number Descriptor field as another Established Timings one to get bunch more supported resolutions+refresh rates instead of needing dedicated timing entries., 9x won't respect it but newer OSes will so it makes sense to do it that way too. In any case I no longer have to jump through hoops to get more tha 1600x1200 on this monitor or higher refresh rates ~
I plan to develop the EDID builder a bit more, give it some user interface and release it so people can try to break their monitors out the limits of EDID too.
I attached comparison of old and new EDID content, as presented by my EDID parser that got written before the builder.
Reply 25394 of 31622, by keropi
very nice!!!!
does the new higher resolution stress the monitor components more?
Reply 25395 of 31622, by Tiido
Stress is function of operating freq, for example 1920 x 1440 @ 60Hz is 90kHz and 2048 x 1536 @ 60Hz is 95.3kHz which both are less than 109kHz of 1600 x 1200 @ 85Hz which the monitor advertised as its preferred mode.
Reply 25396 of 31622, by Kahenraz
mrfusion92 wrote on 2023-09-26, 11:11:
Why use a 5200 Ultra, out of curiosity. A GeForce 4 Ti or a 5600 (non-ultra) I think would have been a better choice?
My personal preference is actually the GeForce 3, when I want to retain some shader support but don't care about or performance is bottlenecked by the CPU anyways.
Reply 25397 of 31622, by mrfusion92
Kahenraz wrote on 2023-09-26, 15:03:
For one good reason, I already had the FX 5200 🤣 I actually have the GF 4 Ti 4600 in the wishlist but since I don't need it urgently I'm waiting some listing at good price (like mostly of what I bought until now, that Voodoo2 was ~30€ + local shipping).
Reply 25398 of 31622, by BitWrangler
I don't think 5200 are actually that terrible in dx7 and dx8, kinda lower half GF3 levels, it's dx9 where it is dire. For the $20 they are worth, they are better value for money than other GF3 or GF2 options.
Given that I've had 4400s and 4600s die running stock speeds from BGA/solder issues on the RAM and two 4200s that do fine, one of which clocks high enough to give ~20k 3DM2k1 I would only attempt to acquire additional 4200s for additional GF4 requiring systems myself. If you want to hang it on the wall and look at it, get a fancy 4600 with original cooler and styling, if you want to use it on the regular, get a 4200 and upgrade cooling.
Reply 25399 of 31622, by gmaverick2k
soldered new reset button on megadrive 2 now i can use saves on mega everdrive x3. success. followed this guide: https://youtu.be/6klndBZFU7Q?si=kP8HxS-LMTYh-f9b
desoldered one capacitor (JPCON 10V 1500uF) from MS-5191 which was bulging. motherboard works but crashes when changing audio properties, this one cap was suspect because of bulge. Still waiting for 10v 1500uF panasonic to come in the post. The motherboard is littered with tayeh capacitors which are shi*e. This was my orignial motherboard for my time computer with onbiard ati rage 128vr. it even boots on post screen with 'time computer systems' in the top part of the post screen.
ordered flux and wick (never used before), decapping wasa pain in the ass, the holes wouldnt clear. had to change tip to fine tip which could poke through multilayerd motherboard.
"What's all this racket going on up here, son? You watchin' yer girl cartoons again?"
Main:z440/2699v3/RTX3060Ti/iFiZenDAC/T480 IPS
98:KT333/AthlonXp 2500+Barton/V3 3000/Vortex2/SC-55
DOS:SS7/P166MMX/V3 2000/PicoGus
XP:Edge72/3570K/GTX970/X-FiTi
