Software rendering <> DirectDraw
First post, by Kordanor
Hey there,
I already read the thread over here but didnt want to necro it:
Re: DirectDraw=software rendering only? Direct3D=hardware rendering only?
I just wanted to check and clarify if I understood everything correctly:
Software Rendering is a more "general term", basically meaning that no 3D hardware acceleration from the Hardware is used. Little or no Resources from the Graphics card are used. The majority of the work is done via the CPU.
DirectDraw is an API made for 2D rendering, which does access Graphics Card Resources like VRAM. DirectDraw can be "abused" for 3D rendering. However no 3D Hardware acceleration is used.
So you could say that DirectDraw is a "way" to do Software rendering (in Windows).
Did I understand that correctly?
My follow up question is then, how much influence CPU / Graphics card has (WITHOUT 3D features).
So lets say that your game stutters quite a bit in Software rendering (lets say some Dos Game like Screamer), and on the opposite side, you have a heavily stuttering game in DirectDraw on Windows.
What woud happen to each case if you throw 5 times the CPU power at it. And what happens if you use 5 times the power of the graphics card (more VRAM and whatever can influence speed on DirectDraw). Or what happens at the opposite if you reduce the power of the graphics card and use an old ISA card for DirectDraw?
I explicitly want to remove Direct3D and newer tech from the discussion and stay at older tech.
Could you generalize that "Software Rendering (Direct Draw or other) is mostly CPU based as long as you have decent Graphics Card for 2D Operations"?
Reply 1 of 46, by BloodyCactus
direct draw is a 2d api that has hardware acceleration.
direct 3d is an api that also has hardware acceleration.
it depends how narrow you want define "software rendering", or the term "render". you can many many things.
if my pixel to plot is already in vram and i just tell it to copy to another place in vram, am I software rendering?? blitting from vram to vram insanely fast, because its memory is local to itself and requires no bus transfers... but then is that considered hardware accelerated or software rendered?
any api that has a "plot pixel" approximation, can be abused for "software rendering"
you can have a 1 pixel sized triangle and plot them using 3d api.. is that software rendering?
lots of 3d games are cpu bound. 5x'ing the cpu, pretty much everything will benefit right?
Reply 2 of 46, by eddman
Kordanor wrote on 2023-09-26, 13:42:
Who said it only applies to 3D? 2D can also be hardware accelerated, meaning the video processor does part of the work; don't know how much though. That's what DirectDraw was for.
With older DirectX versions, you can even run dxdiag and disable acceleration for DirectDraw, if you want to do comparisons. IINM the last version that had the option was DirectX 8.0a.
DirectDraw DirectDraw can be "abused" for 3D rendering. However no 3D Hardware acceleration is used.
DirectDraw is not "abused" for 3D. It's Direct3D that does the 3D. For DirectX up to version 7, Direct3D alone cannot do the entire work process. It handles the 3D rendering, however, for final presentation, DirectDraw needs to be used. The following files are involved for 3D rendering:
DirectX 2-6: d3dim.dll + ddraw.dll
DirectX 7: d3dim700.dll + ddraw.dll
Note that newer DirectX versions still include the old files. A game coded to use, say, Direct3D 6, would still call d3dim.dll, even if a newer DirectX is installed.
Starting with Direct3D 8, all the API interfaces are included in the d3d*.dll file itself; ddraw is no longer needed if you code your game to use Direct3D 8 or newer, either for 3D or 2D acceleration .
It's for 2D accelerated rendering. I don't know if devs could've coded their games in a way to not use acceleration when using DirectDraw, but I don't see why that would be needed (unless to support video cards that do not support DirectDraw acceleration, I suppose).
The term software rendering on windows generally is used for games that do not use any kind of acceleration API, be it 2D or 3D. The video card isn't really involved in processing the graphics code.
However, DirectX did include software only Direc3D APIs too, and some games had them as an option. Those too fall in the "software rendering" category.
Reply 3 of 46, by Kordanor
Ah, alright, so that means that DirectDraw always works together with Direct3D and the terms are more or less exchangable for 3D games because the one wont do anything without the other?
For example I saw this video of POD testing different renders, and he calls the rendering mode "Software - DirectDraw", he could as well have called it Direct3D?
https://www.youtube.com/watch?v=DU5Zi69QPQs
One sample game which calls the Render "Software" would be Quake 2. Another example would be Half Life 1.
So they use less of the Graphics card than for example the "DirectDraw" mode of Pod?
Reply 4 of 46, by Joseph_Joestar
Kordanor wrote on 2023-09-26, 18:35:
No, they aren't interchangeable.
Diablo 2 has both a DirectDraw and a Direct3D mode. Of the two, only the latter provides proper 3D acceleration effects.
Reply 5 of 46, by Kordanor
I guess in Diablo 2 without the Direct3D mode, it just doesnt show these effects?
Can a 3D game (3D as in Gothic, Unreal, Quake) run on DirectDraw without using Direct3D?
I am mostly interested in how the terms are commonly used. Without splitting hairs. I mean I know that without a graphics card you dont have graphics. So everything is technically enhanced by graphics card hardware, because otherwise you would have no picture.
Reply 6 of 46, by feda
Kordanor wrote on 2023-09-26, 19:03:
Yes. Many shooters like Half-Life, Unreal, Quake had a software rendering mode that did not require a 3D accelerator card.
Reply 7 of 46, by Joseph_Joestar
Some can, other's cannot. It depends on whether the game offers DirectDraw as a rendering option.
Generally, when selecting DirectDraw instead of Direct3D, you get no 3D acceleration, no texture filtering, no advanced graphical effects and so on. It's usually used by games for backwards compatibility with older graphics cards which have no Direct3D support.
Reply 8 of 46, by eddman
As Joseph_Joestar mentioned, they are not interchangeable. The game is coded to use Direct3D, but since pre-8 versions cannot do the final presentation by themselves, DDraw has to be involved for that part, that's all. DDraw isn't doing the 3D rendering (although it does still do the 2D elements of the graphics). You don't refer to a game's Direct3D mode as "DirectDraw".
Regarding POD, he's using the term "software", because in DirectDraw mode only the 2D elements of the game are hardware accelerated. The 3D parts are running on the CPU alone.
However, the question is, does that game's software mode even use DDraw? Many 3D games from that period didn't.
I don't know if these games leverage DDraw in their software 3D mode or not. If they don't (and if POD actually does), then I suppose yes, they use less of the video card.
If they're coded to do so, sure, but only the 2D elements would be accelerated. Also, the 3D elements' visuals would be downgraded too, since they require Direct3D. Joseph_Joestar mentioned a few.
Reply 9 of 46, by Kordanor
Alright! These last 2 answers help a lot!
Do you have any idea about the magnitute to compenesate in an "average" game for what is called software or DirectDraw? If you want to have the same FPS as on GLIDE but if you were not allowed to use an accelerator.
To enhance the performance, do you think upgrading the graphics card would have any effect (still software!) compared to upgrading the CPU, or would it be negligible? Or would it be so mixed among games that both can have a big impact in a significant amount of games?
Reply 10 of 46, by eddman
For games that use a 3D engine, the majority of the code is for 3D graphics. In Glide mode, the 3D parts of the game are accelerated by the video card. In software 3D mode, either with or without DDraw, none of it is; all the 3D calculations fall on the CPU.
I think you can already tell that upgrading the video card wouldn't really be of much help, if you're not going to use its 3D capabilities.
Reply 11 of 46, by Kordanor
Thank you!
With the info in this thread I rephrased a little section in a script I wrote. Could you check if there are any factual errors now?
Let's talk about the most important rendering options, starting with the basic one that is supported by almost every game and pc: Software rendering. This is the most basic displaying option, which is completely done without 3D acceleration. Similarly if you select the renderer "DirectDraw" on Windows Games. DirectDraw is purely a 2D API, which can work together with Direct3D for 3D games. But if the selection is called "DirectDraw" you can assume that Direct3D is not used, and therefore neither a 3D acceleration.
And if either Software rendering is selected, or Direct Draw, the heavy lifting will be done by the CPU and the graphics card will only play a minor role in comparison.
However, this means that running 3D games in one of these modes on a CPU of the same time period makes them basically unplayably slow, while also being more pixelated or grainy, which is why back then you usually avoided these whenever possible.
These days, it depends on what you think of the grainier graphics, especially if you're using a modern monitor and depending on what kind of CPU you throw at it.
Reply 12 of 46, by leileilol
eddman wrote on 2023-09-26, 19:21:
Half-Life and (win)Quake definitely do for video memory writes, though WinQuake uses SciTech MGL to go through the DirectDraw interface (MGL having the ability to select VGA/ModeX video modes which DirectDraw didn't always offer). Winquake also had a ddraw-less GDI fallback with writing to system memory (intended to support NT4)
Other than where the byte is placed and how the palettes are handled, there's not a thing about DirectDraw dictating how WinQuake is making graphics.
Reply 13 of 46, by rasz_pl
Joseph_Joestar wrote on 2023-09-26, 18:37:
three, also supports Glide 😀 both Glide and D3D use 3D acceleration to produce faux 3D effect https://simonschreibt.de/gat/dont-starve-diablo-parallax-7/
Reply 14 of 46, by BEEN_Nath_58
It can be 2D too. Not just 3D.
I have to be specific that 3D is not equal to perspective 3D. You can take a game like Half-Life 1 and run it with Software rendering settings and it won't become a 2D perspective game suddenly. DirectDraw obviously supports perspective 3D.
Hence the correction is: DirectDraw is not abused for 3D="3D effects rendering". For example in Half Life, using Software rendering disables "3D effects" acceleration (i.e., Direct3D hardware rendering). Some games, like Terracide instead continue to have a setting that does Software rendering with enabled 3D effects, but only in CPU (called Ramp/RGB/MMX rendering aka. Direct3D software rendering).
My follow up question is then, how much influence CPU / Graphics card has (WITHOUT 3D features). So lets say that your game stut […]
The answer is little complicated from my end. Although games have a Software rendering setting but I have not seen a single game using complete software rendering of DirectDraw. Let's say, MechWarrior 2 Mercenaries Titanium Edition - the game has Software rendering setting but it just means disabling the "3D effects" part aka Direct3D. Everything else seems to be "hardware rendered DirectDraw". I verified this by the fact, pushing HEL rendering to the game fixed all the graphical glitches I previously had (HEL for DirectDraw is equivalent to RGB/Ramp/MMX of Direct3D).
So to answer your question, the results could be different from app to app.
For Direct3D, yes. For DirectDraw it's complicated like I said above.
Reply 15 of 46, by dr.zeissler
That is a very interesting topic!
If something is accelerated I notice it to be smooth or at least smoother than in real software mode.
Dos Quake and even Winquake suffer from stuttering sky...the 3d accelerated versions do have a smooth sky-animation, but it should be also possible if ddraw would be used for winquake.
As I am currently using my Scovery-260 that is equipped with a MGA Mystique 4MB that is a very fast 2D card and also supports D3D but without filtering it would be nice to find smooth games/demos for it. A very latest ZdoomLE works great on that card, unbelievable how good this runs on such an old PCI card.
That is the "B" machine with a K6 processor https://www.youtube.com/watch?v=7iVYgQYeCp0
I do have thes with PII-450 and even with PIII-500 and that makes indeed a big difference compared to the K6 shown in the video above.
Reply 16 of 46, by Jo22
Personally, I recommend reading period-correct books about the matter.
In the Windows 9x era, DirectX 3 to 6.1 did matter the most.
Edit: Having DirectX 7 books at hand (optionally) might be helpful, too. For comparison, I mean.
But be warned, DX7 SDK had deprecated some older APIs/initialization procedures.
The DX7 libs available to programmers may nolonger support them (unlike the runtime).
That's when software-rendering on processor power was the reference for DirectX, still.
At this point in time, graphics hardware usually didn't implement all features of DirectX yet.
Just look at S3 Virge or Nvidia NV1 (aka the "I can't do polygons" graphics chip).
Edit: I'm thinking of the 486DX100 and Pentium 90 era specifically here.
When people discovered DirectX on "normal" computers used in school labs and offices.
Not Pentium II gaming monsters.
DirectDraw is interesting, because it can be used to scale and rotate things (2D stuff).
It's a bit like Mode 7 on the Super Nintendo, I think.
Not sure if it can do parallax scrolling, too, though.
Most VGA drivers shipped with Windows 98/98SE are "DDraw 1.0 capable", at least.
So framebuffer access/video overlay is possible, at least.
Back in the 90s, early Windows 3D games had used flat objects (enemies, items etc) with no depth.
Like it was common for most DOS killer games.
Reply 17 of 46, by dr.zeissler
this ddraw demo looks incredible... like pixelshader-stuff and run on low-end machines under win95! https://www.pouet.net/prod.php?which=273
one of the best lowres effects I have seen.
Reply 18 of 46, by Jo22
dr.zeissler wrote on 2023-11-13, 21:59:
That's cool! I didn't know this was possible so early!
The first time I've seen such a thing was with the graphics demo for the Geforce 256.
https://www.youtube.com/watch?v=PuTXPlCdrgw
Reply 19 of 46, by dr.zeissler
That is no pixelshader, it only looks like pixelshader.
