First post, by aries-mu
Hello Vogons friends!
I'm finding little bites of free time every now and then to check out this old "486 DX" (so the case logo says) PC I've got.
I would be grateful if you could help me to figure the following:
1) Can you identify the motherboard?
2) If it helps, I found the bus speed jumper settings drawings and the actual jumpers, it is set to 33 MHz (see pictures)
3) Oddly, it has 9 L2 cache sockets, 5 of which are populated by chips, but the chips are not as long as the sockets. Can you tell me what kind of L2 cache chips it has? Sync? Async?
4) Can you understand how much L2 cache it has and how much it can hold?
5) If the L2 cache is async, can it get sync cache?
6) Do you know how large is the RAM module and what type? EDO? 70ns? 60ns? There's 2 of them. 2 other slots are empty
7) See the 3 VLB slots? There's a text saying BUS MASTER with 2 arrows indicating only 2 slots. In 1 there's the controller, the other one is empty. The Cirrus Logic GD5429 is in the 3rd slot, which I assume is not BUS MASTER. Is that normal? Or should I move the SVGA in the empty BUS MASTER slot?
😎 Can you see the VLB wait states?
9) I can't identify the VLB controller. Can you tell me anything about it?
10) Where's the CMOS battery? Is it that tiny little green cylinder thing?
11) Any other comments/suggestions/recommendations?
Thanks a lot.
Here are the pictures:
They said therefore to him: Who are you?
Jesus said to them: The beginning, who also speak unto you
"physical media trumps cloud-simp servitude" (Conrad Riker)
Computers should be fun inside not outside! 😉 (by Joakim, VOGONS)
