First post, by Cyberdyne
I like to have all the RTS games that i can play mainly with a mouse and with cheap older computers, but not real retro. So the target is Windows XP. And i have managed to run my list with Windows 7 also.
The list:
CnC Gold
CnC : Tiberian Sun
Red Alert
Red Alert 2
Warcraft (error: no good sourceport exist)
Warcraft 2 BNE
Warcraft 3 (not really the target, because of full 3D)
Dune (sourceport)
Dune 2000
Starcraft
Zed Z whatever (sourceport)
So just looging for bitmapped RTS games. Early full 3D RTS and even FPS games look just ugly.
So maybe you have some aditions.
Reply 2 of 16, by Gmlb256
The non-Definitive Editions of the first two Age of Empires games, not using 3D rendering at all.
Reply 3 of 16, by awgamer
I'd rather play serf city, settlers 2 & dune 2 with DOSBox over listed, top tier is top tier. dune 2 music, fx and ambiance is the best, same deal with serf city & settlers 2, later versions don't hold a candle to the OGs. windows 98 era; close combat: a bridge too far. I haven't played it but star trek away team (2001) looks good to me from the gameplay videos.
Reply 4 of 16, by MrFlibble
Cyberdyne wrote on 2023-10-01, 17:01:
This one is based on reverse-engineered code and is compatible with the original games (savegames and netplay). Windows and Android versions available. Here's a video showing it being played on Android against the original DOS version in DOSBox:
https://www.youtube.com/watch?v=Cx5YchMOvX0
I see you want ports or engine recreations compatible with WinXP, but I have no idea if this one works on XP though.
Dune (sourceport)
You mean Dune II: The Building of A Dynasty. Technically, no projects that exist are source ports, as the source code was never made public. Again, I cannot tell if Dune Dynasty works on XP. Other things like the old version of Dune 2 - The Maker very definitely do work on XP and even Win98, but they are not exceptionally accurate.
DOS Games Archive | Free open source games | RGB Classic Games
Reply 5 of 16, by DracoNihil
Have you tried "7th Legion", "Dark Colony", "Dark Reign 1", and "Earth 2140"? Though I think Earth 2140 was MS-DOS only, I don't remember if it had a native 32-bit Windows executable.
I think "KKND: Krush Kill 'n Destroy" is also a "bitmap RTS" as well, but I'm not sure if that was MS-DOS or 32-bit Windows native.
― Κυνικός Δράκων
Reply 6 of 16, by gmaverick2k
I like to have all the RTS games that i can play mainly with a mouse and with cheap older computers, but not real retro. So the […]
The list:
CnC Gold
CnC : Tiberian Sun
Red Alert
Red Alert 2
Warcraft 2 BNE
Dune (sourceport)
Dune 2000
Starcraft
I downloaded this bin/cue recently : TZAR: Burden of the Crown
tutorial/beginning is a bit childish with weird road rash pc avatar art (don't get this type of artwork), which put me off. looks promising in youtube videos
Also, try stronghold 1, I enjoyed playing that on retro pc
Main: Z440/E5-1650 V4/3060Ti/64GB/iFi Zen DAC V1/Klipsch ProMedia 2.1 THX/Philips 43PUS8808/12
98/DOS: QDI Advance 10T/Pentium iii-S 1.4GHz/V3 3000/Vortex 2/ESS 1868f/MU90/SC-55/SC-88 Pro/LG StudioWorks 995E
XP: Thinkcentre Edge 72/i5-3570K/GTX 970/X-FiTi
Reply 7 of 16, by awgamer
Checked out TZAR: Burden of the Crown videos, serf city/settlers 2 with different graphics and sound.
Reply 8 of 16, by MrFlibble
DracoNihil wrote on 2023-10-02, 06:10:
Oh right, KKND. The original release is for DOS, but the Xtreme version is 32-bit Windows (it has the original campaigns plus expansion scenarios).
Here's a few more Windows native RTS games that should run under XP and later:
Astroseries
Seven Kingdoms + Ancient Adversaries (check out the unique demo scenarios as well)
Seven Kingdoms 2
Rise and Nations + Thrones and Patriots (this one has 3D models for units but everything else is sprites, and the two blend in very well together)
Stronghold (was already mentioned -- it looks very nice, but castle management isn't really my type here)
Majesty: The Fantasy Kingdom Sim
Rising Kingdoms -- this is like Warcraft III, but completely in 2D (from the creators of Tzar)
Submarine Titans (StarCraft clone under water, felt a bit boring to me)
TRIDONIS -- kind of a C&C clone with somewhat better graphics, a demo is available
Knights & Merchants (The Settlers meets Warcraft II)
gmaverick2k wrote on 2023-10-02, 06:45:
This is one of the games which looked cool in the demo (I'm a big Warcraft II fan and this seemed like an elaborate clone/Age of Kings hybrid), but much less so in the full release. I bought this off GOG some years ago and when I started playing (mind you that before that, I'd poked around the demo and even played some skirmish maps in the demo, not just the campaign scenario which seemed ok), unit pathfinding was simply atrocious. I had to replay the second level, which is incredibly simple (walk from one corner of the map to another and defeat a small band of enemy units), twice, because the way my units had absolutely no clue how to group or move around obstacles resulted in a pathetic defeat the first time I played.
Later on I read some forum posts and people actually recommend playing on Easy difficulty to spare yourself some nerves because of these pathfinding problems. I did exactly that, but the game quickly became not very fun to me. Once you get to levels where the AI actually has a base, it has a tendency to dig itself up in strong defences, which easily tear through your forces, and even if you manage to take the base down piece by piece, and it rebuilds very quickly (unlimited resources I guess). As a result, dealing with this swiftly becomes a boring chore, so I finally dropped this for good.
Reply 9 of 16, by gaffa2002
Outlive is a Brazilian RTS released in 2001. Looks a lot like Starcraft.
LO-RES, HI-FUN
Reply 10 of 16, by Kreshna Aryaguna Nurzaman
Emperor: Battle for Dune. Runs pretty smooth on an old laptop with GeForce 310M GPU.
Can't you use DOSBOX for that one? I remember running the game pretty smooth in DOSBOX, on an Intel Celeron M 1.4 GHz CPU, Windows XP.
MrFlibble wrote on 2023-10-02, 18:56:
You beat me to it. And yes, Majesty runs pretty well on something as slow as Intel® Atom™ N280. And I also like the gameplay so much.
Kreshna Aryaguna Nurzaman.
Reply 11 of 16, by MrFlibble
Kreshna Aryaguna Nurzaman wrote on 2023-10-04, 14:00:
As far as I can tell, the OP's looking for 2D stuff. Also I should note that while this game might work reasonably fast on hardware that is considered "old" today, I can tell you from personal experience that I played it back in the mid-2000s on a P4 with 256 MiB RAM and a 64 MiB VRAM NVIDIA card (Win98SE), and while it ran more or less okay on the whole, if I played on hard difficulty and the AI built a really big army, the frame rate would drop to a slide-show once this force started showing up on the screen, making the game unplayable.
Actually, Warcraft should be fully playable natively on WinXP, which is also something that I did back then. One might want to use VDMSound to make the music work properly though. The same applies to Dune II and Command & Conquer.
Reply 12 of 16, by twiz11
The list:
CnC Gold
CnC : Tiberian Sun
Red Alert
Red Alert 2
Warcraft 2 BNE
Dune (sourceport)
Dune 2000
Starcraft
Age of Empires/Mythology I guess any Microsoft published title
Reply 13 of 16, by MrFlibble
gaffa2002 wrote on 2023-10-04, 11:52:
I remember checking out the demo. It does indeed look like SC, but does not really play like it. Somewhat of an odd game but why not.
Also I think I forgot to mention Kingdom Under Fire, which is a South Korean Warcraft II/StarCraft clone. The setting is mediaeval fantasy but the interface isometric view and playing mechanics are more akin to StarCraft. A playable demo is also available.
Reply 15 of 16, by Cyberdyne
MrFlibble wrote on 2023-10-01, 20:34:
This one is based on reverse-engineered code and is compatible with the original games (savegames and netplay). Windows and Andr […]
Dune (sourceport)
WINWAR is a 64BIT windows program, so no dice. and yes I did mean Dune 2.
PS. I am no purist, so I do like modern mouse controls for Dune 2 and Warcraft 1.
Reply 16 of 16, by gmaverick2k
Warrior kings was ok when I tried it years ago. Can't remember much of it, only that it was ok at the time.
Check this list out:
https://youtu.be/r7VYmj2lDXY?si=xQRIAnQu38SOeM81
