Old games that had CD Audio tracks?
Reply 100 of 136, by krcroft
Joseph_Joestar wrote on 2023-06-05, 04:04:
I think it would be beneficial to list the number of CD audio tracks that have been found on a particular disc during your grep search.
I didn't include it and don't plan to make this change, but agree it would be interesting.
The challenge is re-integrating the results with the groups' additions, removals, and improvements - all of which is a lot of manual work.
Would you be interested in making that adaptation to the grep statement and then manually re-layer the groups' modifications? (we could then drop my prior list and yours carry on as a rev2 improvement 👍)
That way, it would be easier to identify games which simply have 1-2 bonus tracks from the ones that actually use CD audio for in-game music playback. The latter usually have 5 or more CD audio tracks on the disc.
Games that use CDDA for spoken dialog often combine many sequences into a handful of tracks and simply seek within the track to play a particular sequence (as opposed to storing them as separate tracks). This is partly because tracks themselves waste some space, but more importantly because the redbook specification is limited to 99 audio tracks.
A couple examples:
- Jones in the Fast Lane (one CDDA track holds all spoken dialog)
- Stellar 7 (one CDDA track holds in-game music plus all spoken cut-scene dialog)
- Inca 1 CD edition (one CDDA track holds all spoken dialog and music)
- Inca 2 (One CDDA track holds all music. Note: some releases have different quality audio or might be improperly ripped) -- thanks Spikey
Reply 101 of 136, by Joseph_Joestar
krcroft wrote on 2023-06-05, 13:50:
Yup, that does seem to be the case. I'm not that good with Linux scripting, so this is all I could do about counting the number of audio tracks:
grep "AUDIO" *.cue -o | cut -d ':' -f 1 | uniq -c
When applied to Tomb Raider Gold, this results in the following output:
9 Tomb Raider Gold CD1.cue
3 Tomb Raider Gold CD2.cue
So the first disc contains 9 audio tracks while the second one has 3. Not ideal, but it gets the point across. Feel free to modify as you like.
Interesting. I imagine some "talkie" adventure games from that time may have used a similar approach.
My retro builds
Reply 102 of 136, by Spikey
Inca 2 definitely has all music in one large Redbook file too. Although some releases have different quality audio (or are improperly ripped), it seems.
Reply 103 of 136, by T-Squared
The Incredible Machine 2
This is the only DOS game that I can think of off the top of my head.
Reply 104 of 136, by MAZter
Moon Buggy (Rondomedia or Sprint Software releases)
Reply 105 of 136, by MAZter
Puzzle Castle (1996) 4 audio tracks
Reply 106 of 136, by HeroponRikiBestest
Joseph_Joestar wrote on 2023-06-06, 06:46:
Yup, that does seem to be the case. I'm not that good with Linux scripting, so this is all I could do about counting the number […]
If you still want this, I attached the results of running this on the current redump IBM pc set. I also attached the results for running it on the mac set, because why not.
Reply 107 of 136, by Joseph_Joestar
HeroponRikiBestest wrote on 2024-09-13, 21:15:
Thanks!
I think this makes a very good starting point. The final list would still need to be curated by hand, to exclude games which ship bonus tracks on the disc but actually use MIDI music during gameplay. Still, knowing how many audio tracks are on each game disc should make this process a bit easier.
My retro builds
Reply 108 of 136, by Spikey
Joseph_Joestar wrote on 2024-09-14, 05:09:
Thanks!
Yeah, I'd say identifying discs that have audio tracks versus those that do not is a great starting point!
Reply 109 of 136, by ludicrous_peridot
I didn't include it and don't plan to make this change, but agree it would be interesting. The challenge is re-integrating the r […]
A couple examples:
Not sure if this has been mentioned, but Deus by Silmarils uses CDDA for digital speech. There's one music trek and then one per each characters' for their spoken phrases. I have only digital reissue, so can't give much detail.
Also, again, pardon if has been mentioned Whizz has audio CD music.
GA-G41M-Combo G41/ICH7 - Core 2 Quad Q9550 - DDR3 1033 - Radeon RX570 - CMI-8738 - CM-300 - Saitek ST-30
Beetle/M/i815+ICH2 - Celeron 566Mhz - Opti 924 - X3MB
https://archive.org/details/peridot-26
Reply 110 of 136, by APOPAP
I am not sure,but I think the CDROM version of Jurassic Park had Cd-rom audio tracks.
Reply 111 of 136, by MAZter
Wild Ride - Surf Shack (19 audio tracks!)
Reply 112 of 136, by Zup
I wonder if it would be useful to split this list on games that HAVE audio tracks and games that USE cd audio.
I mean, Duke Nukem 3D Atomic Edition, Command & Conquer Covert Operations and both C&C: Red Alert expansions have some audio tracks, but aren't used in game. Shadow Warrior, Ignition and Heroes of Might and Magic 2 use their audio tracks.
I'm selling some stuff!
Reply 113 of 136, by eddman
Here, duplicates removed, have at it. I certainly didn't bother to remove the duplicate games that have translated names, or magazine CDs, compilations, etc. If there are messed up names, it's excel's fault. 😆
The attachment PC mixed mode.txt is no longer available
2938 titles, although a few dozen or hundred probably don't count as they are re-releases, although you could argue they do since some re-releases are different from the original.
EDIT: For the most tracks:
Virtual Safari: 99
Tuneland: 98
The Manhole: 96
Alone in the Dark 2 (Japan, DOS/V): 85
Nightmare in the Toy Factory: 79
Firestorm - Thunderhawk 2 (Europe): 77
A Mao A Gou (China) (Disc 2) [English: Tun Town]: 69
Alone in the Dark 2 (Germany): 67
The Musical World of Professor Piccolo: 66
Alone in the Dark 2 (France): 64
Alone in the Dark 2 (Europe & USA) / Betrayal at Krondor: 63
Di Gi Charat Fantasy (Play Disc): 62
Alone in the Dark 3 / Tomb Raider II: 61
That's total tracks, so audio would be n-1.
Reply 114 of 136, by fire_lizard
Blue Force has very nice audio tracks too.
Also Warlords 2 Deluxe.
Reply 115 of 136, by MAZter
Barbie Super Sports had two releases, with and without cd audio tracks:
The attachment img20250208_16254404.jpg is no longer available
Reply 116 of 136, by MAZter
Extreme Motocross (3 tracks)
Reply 117 of 136, by breech
A couple of Criterion games
Sub culture: tracks 2-11 BGM (12 is fake/protection)
Deep Fighter: 2-26 ambience/BGM
Reply 118 of 136, by MAZter
Sesame Street Elmo's Preschool (1 audio track)
Reply 119 of 136, by MAZter
Reader Rabbit: Math - Ages 6-9
