First post, by analog_programmer
- Oldbie
I've one old Abit mobo with nForce4 Ultra chipset, socket AM2 that supports Athlon 64 (X2) CPUs. I suppose it can be base for a system that will be usable in nowadays, but I don't have suitable processor for it. So far I found some local ads for couple of cheap (EUR2.5 to 5) Athlon 64 X2 CPUs, but I'm completely forgotten which one has potential to be good CPU for overclocking. I remember that back in the days 3 to 3.2 GHz was possible on air for these CPUs and (maybe) the older Windsor core was better then Brisbane. Here they are:
#1 Athlon 64 X2 3800+, Windsor core (90 nm), ADO3800IAA5CU (F2): 2000 MHz, 10x, 2x512 kB cache, 1.20-1.25 V (doesn't worth the tryout)
#2 Athlon 64 X2 4400+, Brisbane core (65 nm), ADO4400IAA5DO (G2): 2300 MHz, 11.5x, 2x512 kB cache, 1.325-1.375 V (same as #1)
#3 Athlon 64 X2 5400+, Brisbane core (65 nm), ADO5400IAA5DO (G2): 2800 MHz, 14x, 2x512 kB cache, 1.325-1.375 V (not available at the time I decided to buy this one)
#4 Athlon 64 X2 5600+, Brisbane core (65 nm), ADO5600IAA5DO (G2): 2900 MHz, 14.5x, 2x512 kB cache, 1.325-1.375 V (possible problems with RAM dividers??? and inferior performance to  5600+ Windsor 2800 MHz clock-by-clock)
I'm asking for advise which processor on the list would be best for overclocking on air and why.
UPDATE: None of these are worthy/available. Adding another candidate in the price range up to EUR6:
#5 Athlon 64 X2 5600+, Windsor core (90 nm), ADA5600IAA6CZ (F3): 2800 MHz, 14x, 2x1024 kB cache, 1.30-1.35 V (89 W).
The word Idiot refers to a person with many ideas, especially stupid and harmful ideas.
This world goes south since everything's run by financiers and economists.
This isn't voice chat, yet some people overusing online communications talk and hear voices.
