Reply 640 of 1129, by maxtherabbit
- l33t
NMI halt is handled with writing 0x80 to port 0x70, but the dumper still fails
sb16dump V0.16 experimental support for 4.12
I hope it works ))
No error this time it just freezes after passing the loopback check
maxtherabbit wrote on 2023-10-05, 16:23:No error this time it just freezes after passing the loopback check
Wait a liitle ))
Maelgrum wrote on 2023-10-05, 16:24:maxtherabbit wrote on 2023-10-05, 16:23:No error this time it just freezes after passing the loopback check
Wait a liitle ))
I gave it like 45 seconds how long are you thinking?
maxtherabbit wrote on 2023-10-05, 16:24:Maelgrum wrote on 2023-10-05, 16:24:maxtherabbit wrote on 2023-10-05, 16:23:No error this time it just freezes after passing the loopback check
Wait a liitle ))
Ok, its long enough.
Waiting for @S95Sedan result
Maelgrum wrote on 2023-10-05, 16:19:sb16dump V0.16 experimental support for 4.12
I hope it works ))
Here you go 😉
hmm wonder why it crashed for me
S95Sedan wrote on 2023-10-05, 16:29:Maelgrum wrote on 2023-10-05, 16:19:sb16dump V0.16 experimental support for 4.12
I hope it works ))Here you go 😉
Yes ! We did it ! ))))))))))
sb16dump V0.17 support for v4.12
Content:
v404-8k_49fc3869- Original Creative 4.04 Firmware-----v405-8k_e51aff23:- Original Creative 4.05 Firmware-----v411-8k_4d75e821- Original Creative 4.11 Firmware-----v412-8k_f69d1672- Original Creative 4.12 Firmware-----v413-6k_9e1b22c6v413-8k_e22e9001- Original Creative 4.13 Firmwaresv413-8k_4ca3dca8_patch3- Fixed hanging note bugv413-8k_16a46526_patch4- Fixed hanging note bug- Fixed PSW bug in ExtInt0/ExtInt1 interrupt handlers-----v416-6k_986e5cb9v416-8k_b15514ef- Original Creative 4.16 Firmwares
- Added D52 mappings;
( https://www.bipom.com/dis51.php )
So far, we have ALL 4.xx fw (4.04, 4.05, 4.11, 4.12, 4.13, 4.16).
4.16 and 4.12 was not previously known as dumped. Great job done !
Мy sincere gratitude to everyone involved in the project.
Special thanks to main testers: @S95Sedan and @mattw !
Maelgrum wrote on 2023-10-05, 16:34:sb16dump V0.17 support for v4.12
Still doesn't work on my CT2760
maxtherabbit wrote on 2023-10-05, 16:48:Maelgrum wrote on 2023-10-05, 16:34:sb16dump V0.17 support for v4.12
May be NMI sensitive mb ?
Now since no new firmware will be released by Creative, the fun with dumping can only continue with clone cards. On the other hand have you checked how 4.16 is fixed against hanging notes bugs? Looks the most proper way to improve the firmware is to make fixes on 4.13.
Maelgrum wrote on 2023-10-05, 16:49:maxtherabbit wrote on 2023-10-05, 16:48:Maelgrum wrote on 2023-10-05, 16:34:sb16dump V0.17 support for v4.12
Not sure it has anything to do with the NMI, once I masked it by writing 0x80 to port 0x70 the v0.16 dumper failed gracefully
Maelgrum wrote on 2023-10-05, 16:47:So far, we have ALL 4.xx fw (4.04, 4.05, 4.11, 4.12, 4.13, 4.16). 4.16 and 4.12 was not previously known as dumped. Great job […]
Nice job on the coding.
I changed my post a bit aswell and added d52 mappings i have so far, as only 4.05 was partially done.
Used https://github.com/schlae/sb-firmware/tree/master as reference.
Has anyone done a sb16dumper run on a 4.11 card yet?
maxtherabbit wrote on 2023-10-05, 16:52:Maelgrum wrote on 2023-10-05, 16:49:maxtherabbit wrote on 2023-10-05, 16:48:Still doesn't work on my CT2760
Now, with known dump of 4.12, i can try to find other attack route. May be without NMI triggering in process ))
