First post, by gil22
Quick question.......
Is a game.exe shortcut's...
"properties"
"program"
"advanced"
"Compatible timer hardware emulation" option
The same as VDMSound's
"Cap dos timer frequency" / "try to reduce CPU usage" options?
Thanks.
Reply 1 of 6, by Snover
Not quite. I believe the first option (in VDMSound) is, but the latter "reduce CPU usage" is not.
Yes, it’s my fault.
Reply 2 of 6, by Unregistered
You wouldn't think that putting in a user name in would be that difficult...
Delete me 'cause I'm an idiot!
Reply 3 of 6, by gil22
Let's try this again....
Ok, that sounds logical.
Thanks again.
Reply 4 of 6, by Nicht Sehr Gut
Originally posted by Unregistered Delete me 'cause I'm an idiot!
Strange post of the day...
Reply 5 of 6, by gil22
"Strange post of the day..." -Nicht Sehr Gut
Thank you!
Reply 6 of 6, by Nicht Sehr Gut
Originally posted by gil22 Thank you!
Ok, so that was you. That explains the next post.
Do I win a prize?
Sure. Next time I throw a spoon at somebody, I'll make sure it doesn't hit you.
