superfury wrote on 2023-10-06, 20:07:
So, basically, all instructions end with that RNI instruction?
Yes.
So that means that since that 'extra cycle' on the next instruction is the fetch for the next instruction itself, but it's counted as one extra cycle (or is it?), thus the deal with your cycle_nx function essentially is that nothing changes?
So basically, I should either add 1 cycle to the cycles_nx* count or leave it alone? And take all other instruction cycles literally? And no new logic on the fetching of the first byte of the next instruction (as that's done immediately after the EU finishes anyway in UniPCemu, directly after initializing the instruction states for the new instruction)?
I'm sorry, I'm not following.
You have a several ways to get cycle traces of arbitrary code execution on an 8088 - you have reenigne's xtserver or xtce emulator, and you have MartyPC's cycle log facilities. If you are willing to do some tests with them, the timings should become clear to you.
EDIT: If I think I understand what you are asking, you would subtract 1 cycle from any calls to cycle_nx - they allow for the terminating microcode instruction line # to be passed through but not executed. A lot of what MartyPC does is complicated by my desire to produce microcode listings in cycle traces (a feature that still isn't quite working right). To that aim, i wanted a facility to indicate the microcode line # to be executed in the future. Unfortunately this does make following my source code more confusing, maybe I should revisit my approach.
MartyPC: A cycle-accurate IBM PC/XT emulator | web version: https://martypc.net | https://github.com/dbalsom/martypc
