The Soundblaster DSP project
Reply 760 of 1053, by Maelgrum
First attempt of building new fw from source code.
Changes (from original V4.13)
1. Hanging note bug fixed
2. ADPCM problem fixed
3. Overall speedup - removed all debug x-bus trace port access
4. All unused junk in upper 2k is removed - flash in MCU must be programmed faster
Main question - is this build working ? ))
Reply 761 of 1053, by S95Sedan
Maelgrum wrote on 2023-10-07, 18:01:
First attempt of building new fw from source code. Changes (from original V4.13) 1. Hanging note bug fixed 2. ADPCM problem f […]
Will test in a second.
Edit: Hangs on boot aswell, same as the 4.16 one. Dont know what part of the code is fixed/changed but its doing something.
Does this one work in your assembler aswell, its one that works with as31.
(Havent done the names yet which were done in the other file.)
    dsp_v413_as31.zip
    8.89 KiB
    42 downloads
Reply 762 of 1053, by Maelgrum
S95Sedan wrote on 2023-10-07, 18:19:
And original V4.13 works on this card ?
If original V4.13 wont work, this version will not work too ))
you want me to test compilation of this .asm, in keil ?
Reply 764 of 1053, by maxtherabbit
Not working for me, DIAGNOSE does not find the card
Reply 765 of 1053, by Maelgrum
maxtherabbit wrote on 2023-10-07, 18:45:
But original V4.13 works ?
Reply 766 of 1053, by mattw
maxtherabbit wrote on 2023-10-07, 18:41:
AT89C52-24JI/C is not OTP. You can reprogram it many times
thank you - I copied and pasted your comment to my previous post - just to keep all info at the same place - it seems I confused "AT89C52" with "AT87C52", which is OTP.
Reply 767 of 1053, by S95Sedan
Maelgrum wrote on 2023-10-07, 18:41:
And original V4.13 works on this card ? If original V4.13 wont work, this version will not work too )) […]
The unmodified .asm one thats a 100% match works after compiling, the one with your changes doesnt. (this one Re: The Soundblaster DSP project )
Yes, so we known it works in either program.
Reply 768 of 1053, by maxtherabbit
Maelgrum wrote on 2023-10-07, 18:46:
Original 4.13 as well as 4.13 patch 3 have both been confirmed working on this card
Reply 771 of 1053, by Maelgrum
maxtherabbit wrote on 2023-10-07, 19:01:
Maelgrum wrote on 2023-10-07, 18:54:
Ok, this version leaves all X-bus reg 5 exchange in place
will it work ?
yes!
Excellent !
not only hanging note, but ADPCM bug also fixed here ))
Reply 774 of 1053, by Maelgrum
S95Sedan wrote on 2023-10-07, 19:02:
will it work ?
Same here, this one works fine.
BTW, you have one card on which you successfully tested V4.16. First build should work on this card.
Reply 775 of 1053, by S95Sedan
Maelgrum wrote on 2023-10-07, 19:04:
will it work ?
Both were on an awe32 ct3900, but can test on either incase more things been changed to ensure compatibility.
Reply 776 of 1053, by maxtherabbit
will it work ?
That was his CT1740 (no CT1747 bus interface)
