First post, by yukiko
hi all,
Im using the attached
dosbox_sod_single.conf
4.3 KiB
46 downloads
dosbox_sod.conf
11.18 KiB
43 downloads
main.bat.txt
84 Bytes
50 downloads
and experiencing a problem on startup, in detail getting this error when the line 67 exists
and getting this error when the line 68 exists
if not line 67+68 exist, run flawless... The need is to create more menu entries... I search over forum & world wide web. I found only, the source code part throwing the error.
Please advise, is any way to avoid this error or a even better way to do a menu?
Reply 1 of 4, by zirkoni
yukiko wrote on 2023-10-08, 09:50:
Yes
Use a front end:
DOSBox Game Launcher (DOSBox Frontend)
D-Fend Reloaded (DOSBox frontend)
or
Use a menu program:
https://www.target-earth.net/wiki/doku.php?id … og:x86_launcher
New MS-DOS Games Launcher / Menu System App
I even made one very simple one myself some time ago:
https://github.com/zirkoni/zmenu
https://youtube.com/@zirkoni42
Reply 3 of 4, by yukiko
@zirkoni
I will go with your solution, enlighten me how to use proper the ANSI on menu, for example now I have
[?7h[255D[0;1mM[36mo[0;36mo[34mnstone [1;37m(1992)[0m[30mx C:\MOONST~1 MS.EXE […]
C:\MOONST~1
MS.EXE
Another World (1991)
C:\ANOTHER
ANOTHER.EXE
but the selected option is NOT look /selected/ in menu...
[edit]
damn, let it be, dont like the 1 column with arrows keys... I just call a batch on autoexec section of dosbox_sod_single.conf like
[ipx]
ipx=false
[autoexec]
@echo off
mount c ".."
c:
menu.bat
seems that this solving the problem.
Reply 4 of 4, by BloodyCactus
this looks like the GOG setup for Spear of Destiny... GOG likes to use two configs like that. I find all gog configs to be terrible.
