Reply 980 of 1988, by thp
New build from this commit: https://github.com/thp/sbemu/commit/37f9be97c … c7a96d5986b263d
I trimmed it down to a few registers that I think matter, and left out the ones that probably don't affect operation.
Please let me know if this build still works on your machine (if yes, we can try trimming it down further, if no, we have to see which registers to add to make it work again).
Edit: The pitch issues might be related to overwriting the "PCM front DAC rate" register with the Win98 value. The new build might fix that.
dr.zeissler wrote on 2023-10-07, 20:46:- SBL seems to be a bit slow paced on point https://www.pouet.net/prod.php?which=68187
- SBL sound good in "setup" in Duke3D center, right and left test sounds a bit weird and high-pitched.
