Reply 60 of 123, by aries-mu
BitWrangler wrote on 2023-10-05, 23:24:Well when 286 boards first got SIMM or SIPP, the "normal" size was probably the 256kB and the special order "Holy heck are you running a shuttle mission" 1MBs maybe just existed for near the price of the whole system unit. So boards may have got 8 slots with the idea they could be filled eventually with a whopping 2MB. Though most are probably wired to take at least 1MB SIMM. But anyway, huge amount of slots was initially expecting user to buy the affordable smaller SIMM most likely. But what the heck, 1MBs haven't gone to stupid pricing so fill 'em if all if you like. 9 chip modules are probably "safest" for 286 and older 386, may only need 100 or 8ons, but if you buy 70, they at least won't slow your 486 to a crawl if you wanna use them elsewhere later.
Interesting! I didn't know that "9 chips" thing! Thanks!!
Robbbert wrote on 2023-10-05, 22:25:Another way to look at is, if the computer has the slots for extra memory, there must be a way to use it, so put in as much RAM as you can.
After all, the slots wouldn't be there if they didn't do anything.
Good point!
mkarcher wrote on 2023-10-05, 23:01:Robbbert wrote on 2023-10-05, 22:25:After all, the slots wouldn't be there if they didn't do anything.
"Creating demand for RAM modules" is also "doing something" 😉
jakethompson1 wrote on 2023-10-05, 23:10:mkarcher wrote on 2023-10-05, 23:01:Robbbert wrote on 2023-10-05, 22:25:After all, the slots wouldn't be there if they didn't do anything.
Would 286 board vendors have had OS/2 in mind when deciding how many memory expansion to put on their boards?
Good point!
digger wrote on 2023-10-05, 23:33:Dune II requires at least 2MB of memory (conventional memory + XMS, not EMS) for PCM audio playback. When only conventional memory (or not enough extended mory) is available, only music and non-digitally-sampled sound effects can be heard in the game. The installer will warn the user about this when no extended memory is detected.
It's a real mode game, so it runs on a 286. So that's at least one game that you can only play in its full glory on a 286 when you have at least 2MB of RAM installed. 🙂
Sounds thrilling! I never played Dune II in the joyful days, but you succeeded in transmitting me the feeling!
douglar wrote on 2023-10-06, 00:34:Maybe. However you would have to use OS/2 1.3, which was, uhh, spartan to say the least on a 286 unless you had 16 bit OS/2 app […]
jakethompson1 wrote on 2023-10-05, 23:10:Would 286 board vendors have had OS/2 in mind when deciding how many memory expansion to put on their boards?
Maybe. However you would have to use OS/2 1.3, which was, uhh, spartan to say the least on a 286 unless you had 16 bit OS/2 apps. With no virtual 8086 support, it was not a better DOS than DOS. I remember getting lemmings to run in its single tasking DOS compatibility session once upon a time, but it wasn’t really stable.
But if you want to put 8mb in your 286, I say do it, as long as you dont mind the longer mem check post time. It is pretty much a free upgrade compared to how much it would have cost in 1988, so have at it. Maybe it makes windows 3.1 better.
Is it possible to use the extra ram for smart drive without XMS?
Gotcha, thanks.
Yes, indeed, I also wondered things like that: Smartdrv and/or Ramdrive
Jo22 wrote on 2023-10-06, 09:57:I know it's a bit annoying, but.. I've did some testing 286 vs OS/2 1.x over here. (^We weren't always dead serious in that thre […]
(^We weren't always dead serious in that thread, btw. A bit of poking fun at each others..)The OS/2 compatibility box is quite limiting, but it has good technical reasons here for.
The whole first 640KB (default setting) are essentially being exclusive for the synthetic DOS.That's why 640KB are being "lost" for OS/2 and OS/2 needs more memory than DOS without any further doing.
In addition, a small HDD cache is being running, too.If OS/2 is running, it can use its own drivers for networking and filesystem (in theory).
It's not needed to load any DOS drivers for this into first 640KB.
So ideally, those 640KB in the DOS "penalty box" are usually free to DOS applications.On a contemporary 286 PC running PC-DOS 3.30, even less memory would be available.
On the other hand, the latest 16-Bit OS/2 (v1. 3) was around when MS-DOS 5/6 and memory managers like QEMM/EMM386 were available.
And they could "out source" parts of DOS and applications beyond 640KB, liquidishing the need for 16-Bit OS/2 here.But then, there's the filesystem. The latest 16-Bit OS/2 supported HPFS, which had advantages over FAT.
And like with Windows NT, OS/2 could run DOS applications on a foreign filesystem.
Very interesting, thanks!
@everyone else
Wow guys, so much interesting stuff you added which I missed and I can't find a moment to finish reading, I will... Thanks all
They said therefore to him: Who are you?
Jesus said to them: The beginning, who also speak unto you
Computers should be fun inside not outside! 😉 (by Joakim)
