Reply 4420 of 5269, by Repo Man11
- l33t
BitWrangler wrote on 2023-10-11, 17:29:I think there's only 3 PSUs total, not too fussed if those don't work, as I have 3 or 4 AT boards with ATX power connectors, so by the time I swap everything around, I can be using ATX with those. I am kinda more excited to have "any metal vaguely resembling the shape of an AT case" because I had more AT board projects planned than cases available. They might not get restored to original color though. I have half a dozen rattle cans of silver paint, same of bright white, so odds are they're gonna get the covers painted with that at least. That fourth in line may get attention first. Because I have two more similar pattern minis, one midi and one full tower kinda matching. So I might do a 286, 386, 486, Pentium and PIII matched set. I may swap the cover to another mini though so I don't have a bright white one standing out.
The middle one might in fact have it's cover preserved indoors, I keep thinking I seem to have one more cover than machines. I think it's the one that is like a quarter inch shorter than common, which the 4th one represents, there's a number of almost identical chassis in shape and size with different facias in mini-towers. Not sure number 2 is part of that group, but might be similar to number 5, which was a later, fast 486, slow pentium era kind of common one.
I don't know if you've ever used a bead blaster, but these cases would be a perfect candidate for your first time if you haven't. Paint doesn't stop rust - bead blasting down to bare metal or phosphoric acid are the two main options for preventing it from returning.
