First post, by wutang61
Did a little digging, found some very old information on 10 year old posts so I figured it was time for a new thread.
My mobo allows bios based switching from AGP-PCI for graphics. I figure, with this toggle I should be able to run 2 separate GPU’s in the system.
The main one would an AGP 5900 ultra.
The second being an ATI Rage 2 + DVD.
Just concerned how catalyst and forceware could conflict being overlapped in 98.
This is strictly a science experiment as I physically do not require the RAGE 2. I’m only playing with the idea to run a version of mechwarrior 2 that uses the RAGE API.
I could make a second bootable 98 installation on a separate drive to isolate the drivers. But curious if anyone has had any luck with a similar setup like this.
