First post, by SKARDAVNELNATE
- Oldbie
One thing that seems to be increasingly popular is Steam or some other strange installation requirement to unlock files before you can play. I worry if this will limit how many times I can install something on a system. Or if I can still play it after upgrading to a new system. Also I want games I can reminisce about 10 years later and still be able to install. How do I know it will still be supported then? Maybe if a game is no longer supported companies could release an installer that bypasses the requirement but if a game has it I won't get it until then.
Another thing that's becoming common in games is using checkpoints instead of allowing you to save the game yourself. I usually find that frustrating when I'm doing well but can't save, then it saves on it's own at a point that I'm doing badly. I don't mind if a game autosaves but I like to be in control of it as well. It's why I gave up on FarCry and probably won't get Crysis if it uses the same.
Here are some games I'm considering but I'm worried might have something to hinder it. Or maybe they're just not that good.
Clive Barker's Jericho
Indigo Prophecy
Prey
S.T.A.L.K.E.R.: Shadow of Chernobyl
So for me which ones wouldn't be worth bothering with?
