First post, by kahuna
- Newbie
Hi all,
Just wanted to share a somewhat interesting behaviour I'm seeing running Prince of Persia.
What I'm using is a K6-III+ based machine with a Sound Blaster 64 AWE GOLD that I have connected to an MT32-Pi.
The Prince of Persia version I'm running is 1.3.
The thing is, if I run the game without disabling the cache of the CPU, the MT32 takes care of both music and sound effects.
However, when I disable the CPU cache and lower the CPU speed, I get the music from the MT32, but the sound effects come from the Sound Blaster directly.
The latter is actually the configuration I want, and that's what I have configured using 'setup.exe' 😀
I also tested with SoftMPU loaded, same results.
Not sure if it's just me...
Be free!
