Reply 25660 of 31305, by Meatball
H3nrik V! wrote on 2023-10-23, 09:13:
I made a stupid move a couple of days ago ... I'm on the lookout for a Pentium III 933 slot-1. They are horribly priced on a well-known auction site - like +100US$. Then my saved search found a Dell motherboard (Precision 420) with one 933 Slot-1, memory, C-RIMMs (I think, or the memory banks were full) for US$25 or best offer .. Cheap as I were, I put in an offer, hoping to get it for $20 - but within no time, it was sold at listed price ... Of course ... So stupid of me ... D'OH!
I used to make that mistake. If I see something that is a good deal, most certainly, someone else in the world sees it, too.
Reply 25661 of 31305, by H3nrik V!
debs3759 wrote on 2023-10-23, 10:00:
Blimey! I sold a 1 GHz slot 1 for £7 recently. Either I under charged, or the 933 you saw is overpriced (probably a bit of both). I'm hopeless at pricing things to sell 😁
Well, the 933 is a bit of an oddball in that regard - all I've seen looks Dell OEM'ish ...
BTW, I've made a reply on that exact thread on CPU-World - have you seen that? 😉
Reply 25662 of 31305, by H3nrik V!
Meatball wrote on 2023-10-23, 11:53:
It was the first time, I did that - but I've definately learned from it 🤣
Reply 25663 of 31305, by debs3759
H3nrik V! wrote on 2023-10-23, 12:31:
I had missed, but I just replied. I don't think I have any early enough to be unlocked.
Reply 25664 of 31305, by kingcake
Cleaning up and prepping an Athlon XP 2000+ and an MSI MS-6570 K7N2 mobo. I even found the copper shim and heatsink I bought back in 2001! Installed a new 60mm fan on the heatsink.
The attachment image_50759937.JPG is no longer available
The attachment image_50746113.jpg is no longer available
The attachment image_50795521.jpg is no longer available
Which GPU should I go with for this build? I have the following AGP cards:
Rage 128 Pro Ultra
Matrox G550
Radeon X800
Radeon 9600se
Radeon 9800se
Geforce2 MX200
Geforce 6200
Reply 25665 of 31305, by BitWrangler
If that's your best AGP combo then give it the X800, but 9800SE is a bit more period and decent enough. If you were only going to do DX7 Win98 stuff and below, then maybe you'd consider the MX200.
Reply 25666 of 31305, by BitWrangler
H3nrik V! wrote on 2023-10-23, 12:32:
I've been a penny pincher for four decades, but last 3 years the financial pressures have lifted and I'm fortunate to not have to just scrape by week to week. Thus I am trying to stop myself haggling out of habit on stuff that's already cheap. Not that I'm gonna throw money away either, just I can cheerfully pay the asking on stuff that's good value so shouldn't begrudge the last buck or something I would have tried to knock off.
Reply 25667 of 31305, by DerBaum
The lack of individual addressable RGB LEDs and orange car wrapping film in modded early 2000s industrial PCs is not accaptable!
The attachment 2023-10-23 19.09.01.jpg is no longer available
I cant wait to see how it will turn out. I try to just use the leds in placec where you cant see them directly (below the backplane, behind fans ...) .
FCKGW-RHQQ2
Reply 25668 of 31305, by PcBytes
Had some fun with an ASRock P4Dual-915GL.
file.php?mode=view&id=176873
There's just something funny and silly about pairing a SL6Z5 Northwood HT with a nicely decked-out Sapphire HD4870 1GB GDDR5 video card 🤣
Reply 25669 of 31305, by kingcake
Thermal grease on a ~20 year old video card. It was like concrete. Completely dry and gritty. Cleaned it off and repasted with Arctic MX-4.
The attachment Screenshot 2023-10-23 190633.jpg is no longer available
Reply 25670 of 31305, by kingcake
Too hot for an Athlon XP 2000+? I'm worried the copper shim I used is preventing good contact. This is the temp in free air. Current room temp is 75F.
The attachment image_50452225.JPG is no longer available
The attachment image_50771201.JPG is no longer available
Reply 25671 of 31305, by brunobox99
Changed the 8x8 and 8x16 fonts on my Trident PCI video card BIOS.
Reply 25672 of 31305, by BitWrangler
kingcake wrote on 2023-10-24, 02:03:
That's only a 60mm fanned sink right? What would be called "stock" size for an XP, so 53 is about expected, and may go up to 70 full load. The sinks with about a 40cfm 60mm screamer on like a Volcano 6CU would be more like 40 idle, 60 load, then you'd get sinks like an SLK 900 which would have it in the 30s with 50s load with a ~50cfm 80mm on.
Reply 25673 of 31305, by kingcake
BitWrangler wrote on 2023-10-24, 03:05:
Yep 60mmx15mm. Darn, I was hoping it would perform better than the stock HSF since it's a solid copper base. Guess this chip will just run warm because I'm not spending $40 on a NOS socket A performance cooler 🤣
Reply 25674 of 31305, by appiah4
DerBaum wrote on 2023-10-23, 18:05:
Heresy... 🤣
Reply 25675 of 31305, by DerBaum
appiah4 wrote on 2023-10-24, 08:24:
Heresy... 🤣
Its all reversable ...
excexpt maybe the huge hole in the side 😏
Re: What retro activity did you get up to today?
FCKGW-RHQQ2
Reply 25676 of 31305, by gmaverick2k
looked in a cpu holder box thing and surprised to find a tualatin 1.4-s cpu and a pentium 3 1ghz cpu. 🤣, kept these from a failed tusl2-m motherboard build over a decade ago. 🤣 😀
"What's all this racket going on up here, son? You watchin' yer girl cartoons again?"
Main:z440/2699v3/RTX3060Ti/iFiZenDAC/T480 IPS
98:KT333/AthlonXp 2500+Barton/V3 3000/Vortex2/SC-55
DOS:SS7/P166MMX/V3 2000/PicoGus
XP:Edge72/3570K/GTX970/X-FiTi
Reply 25677 of 31305, by BitWrangler
kingcake wrote on 2023-10-24, 05:09:
It was generally said that most socket A temperature readings were 10C higher than other platforms, so might not be as high as it seems like.
Edit: this is the best deal I know about in Socket A higher capacity, but not super high end coolers, https://www.cablesalescanada.com/index.php?ma … products_id=227
Reply 25678 of 31305, by kingcake
BitWrangler wrote on 2023-10-24, 12:21:
Cool site. Great prices on retro cpu coolers. I bought a few to make the shipping worth it.
The attachment Screenshot 2023-10-24 163213.png is no longer available
Reply 25679 of 31305, by ElectroSoldier
gmaverick2k wrote on 2023-10-24, 11:27:
Nice.
Like a cheeky little present from yourself to yourself.
