First post, by JF_Sebastian
Hi guys,
today I got my retro PC fully up and running. Now I am running my Gigabyte GA586s with a P1-MMX 200Mhz. Since the motherboard's SIS 5571 chipset has no UDMA support and performs poorly, I decided to upgrade the system with a Dawicontrol DC-150 RAID. Flashed with a 2007 bios, it runs and boots without problems under Windows 98 se. But in the ATTO benchmark I get a maximum of 36MB @Write and 41MB @read. These are of course not bad values, but can someone explain to me where the bottleneck is?
Best regards,
JF 😉
Boot Up or Shut Up!
________________________
Asus P/I-P55T2P4 Rev. 3.10
Asus USB/MIR Rev. 1.11
AMD-K6-III/450AFX @6x83MHz; 2.4V
4x128MB EDO RAM 60ns
MATROX Mystique MGA-1064SG-D 4MB
Diamond Monster 2 8MB
DELOCK 91620 - CF to IDE
Reply 1 of 5, by MadMac_5
What sort of storage device are you reading/writing from/to to get those numbers? If it's a Compact Flash or SD adapter, the adapter or flash media you're using could be limiting your throughput.
Reply 2 of 5, by JF_Sebastian
MadMac_5 wrote on 2023-10-28, 14:14:
Hello Madmac_5,
thanks for your reply. I am using a hard drive - seagate barracuda 7200 250gb. I guess it should be fast enough to get over 40MB R/W. I don't know if I'm wrong but with the DC-150 the chipset shouldn't affect the bandwidth anymore, right?
Best regards,
JF
Boot Up or Shut Up!
Reply 3 of 5, by JF_Sebastian
JF_Sebastian wrote on 2023-10-28, 14:32:
Hello Madmac_5, […]
Hello Madmac_5,
Best regards,
JF
.....of course it is almost 8 times faster than with the onboard IDE controller and the original Seagate Medalist. 😁
Boot Up or Shut Up!
Reply 4 of 5, by rasz_pl
Google is broken when it comes to looking this kind of info nowadays, will spam you with everything but the actual relevant results. Still I managed to find anegdotal evidence in line with your results https://news.asbis.com/news/suppliers/seagate … upbeat-reviews/
"Compare that with the 57MB/sec. recorded from a 250GB Seagate hard drive (ST3250824AS 3.AA) also installed in the system."
40 vs 57 makes little difference when you consider 200mhz vs 2007 system in the link.
Reply 5 of 5, by JF_Sebastian
rasz_pl wrote on 2023-10-28, 15:14:
Hello rasz_pl,
that surprises me. Thanks for the article! Then I would say that the performance is quite acceptable for such an old system.
Greetings,
JF
Boot Up or Shut Up!
