PS2 Mouse not working ?
First post, by rain
hi i have old zida BX98-3D slot 1 mobo. when trying ps2 mouse work , mouse led is working but windows 98 se not detecting mouse. trying bios settings but cant find any option for ps2 mouse?
Reply 1 of 10, by paradigital
Does the motherboard have USB, and if so have you disabled it?
On my Asus K7M (Slot A), if I disable USB for some reason I also lose the mouse PS/2 port (keyboard continues to work).
Reply 2 of 10, by rain
paradigital wrote on 2023-10-28, 16:53:
Usb is enabled
Reply 3 of 10, by Horun
Are you using the original PS2 back plate or an after market one. With the LED working it is getting proper 5v but maybe the data and clock signals are not wired proper to JP12...
Reply 4 of 10, by rain
Horun wrote on 2023-10-28, 20:10:
Its not original back plate. i dont know it is related but com (serial ) port also not working
Reply 5 of 10, by rain
Here are some pics of motherboard and bracket
Reply 6 of 10, by Repo Man11
Here's the mouse pin outs from the manual; most likely your PS/2 plate isn't wired correctly for this motherboard.
Reply 7 of 10, by Repo Man11
For an example, here's one from a Soyo manual. Caution: not all PS/2 backplates use the same color codes for the wires! I had one that I had to verify the wire positions with a meter.
Reply 8 of 10, by Horun
To me it looks like the plate connector is a dual 4 pin but the board needs a 5 pin.
Reply 9 of 10, by Repo Man11
You serial port issue is likely the same since there is more than one pin out for serial ports. This is the sort of thing that demonstrates why the ATX standard was a very welcome step forward from AT motherboards.
Reply 10 of 10, by Repo Man11
Yes, that connector looks as though it's for a pinout like the one on the right in this image. Having saved lots of odds and ends, I have a number of five pin connectors in my spares box that I could use, hopefully the OP does as well. If you never have, removing and replacing the wires can be done easily enough, just take care to not pry them out too far.
