There is an update with the situation around this cursed TNT2 Pro. Still I do not know if it is for good or worse 😁
Now officially this card has all symptoms of dead BIOS: the screen is completely dark, but system boots normally and no complains about videocard errors during POST (I always use POST test ISA/PCI card). How I achieved this?...
Well, I just removed the EEPROM (at least I thought its an EEPORM until today) chip during my checks for cracked or shorted SMD resistors and caps. None damaged SMD components found so far... I do not know exactly why I removed the BIOS chip, maybe some habit just to mechanically clean its pins as it is removed-reinserted into socket. And after this simple manipulation there was no more videosignal from the card.
So... Today I decided to try again reflashing of BIOS, but "in light" using my "self-revived" PCI S3 as prime videocard in the system. And I noticed something strange. The NVFLASH.EXE finds the TNT2 card, but can not flash nothing - does not recognizes the BIOS chip with "-c" argument. Ok, tried the FLASHROM (DOS version) - same story: with "-p gfxnvidia" arguments it recognizes the card as supported "programmer", but also complains that there is no EEPROM chip supported to read from nor to write to. So I decided to remove the stupid sticker "RIVA TNT2 PRO Copyright(c)99" which was covering the EEPROM to see what unsupported chip it is. SURPRISE! It is Amic A276308-70 OTP EPROM! No way! One time programmable at 12V and readable at 5V EPROM:
The attachment P7050020.JPG is no longer available
So it turns out that several days ago I've reflashed nothing "in the dark" with those autoexec.bat-ish automated flash attempts. It's OTP EPROM chip for even cheaper videocard.
I'm just wondering, can anybody here confirm possible OTP EPROM BIOS "bit rot"?
If this is legit suggestion I'll continue to search for supported EEPROMs 32 or 28 DIP package with acceptable price. There are not so many options thou. NVFLASH 3.18 supports these 64kb 5V EEPROMs:
SST 29EE512 , 64Kx8, 5.0V, 128B page
SST 39SF512, 64Kx8, 5.0V, 1B page
Atmel 29C512, 64Kx8, 5.0V, 128B page
Atmel 49F512, 64Kx8, 5.0,3.0,2.7V, 1B page
WBond W29EE512, 64Kx8, 5.0V, 128B page
The word Idiot refers to a person with many ideas, especially stupid and harmful ideas.
This world goes south since everything's run by financiers and economists.
This isn't voice chat, yet some people overusing online communications talk and hear voices.
