The "Why even bother?" PC - Intel Timna build
First post, by Katmai500
Background:
For folks who are not familiar, Intel Timna was a project in 1999/2000 to integrate a Coppermine Celeron CPU with a RAMBUS memory controller and i752 graphics all on a single piece of silicon. The goal was to simplify motherboard designs for the sub -$600 PC market. Unfortunately, RDRAM prices never came down to reasonable levels, so Intel had to resort to pairing Timna with the flawed Memory Translator Hub (MTH) to allow use of cheaper SDRAM. Intel also paired the MTH with the i820 chipset. Performance was worse than native-SDRAM solutions such as the 440BX, and there were stability issues. After the MTH was recalled and vendors showed little interest in selling Timna systems, intel cancelled the project.
This build is probably the worst possible combination of hardware for a retro gaming build: a fairly slow Celeron processor, intel integrated graphics with i810 levels of performance, and no AGP slot for upgradability, but it's super rare and cool so here we go.
The Build:
First we start with an Intel Timna engineering sample CPU: Q-Spec QV18, rated for 667 MHz and manufactured in May of 2000. It looks a lot like a standard Socket 370 Celeron, but the pin-out is slightly different.
The attachment QV18_Timna.jpg is no longer available
The attachment Timna Pins.jpg is no longer available
Next we need a motherboard. This is an ASUS TMA-PL pre-production Socket 370S motherboard for the Intel Timna. It has no chipset northbridge, since that functionality is integrated with the CPU. So all it has is the MTH for memory translation and an ICH2 southbridge.
The attachment IMG_5558.jpg is no longer available
The attachment IMG_5572.jpg is no longer available
Since this is a low-cost Celeron build, I'm sticking with the integrated Timna graphics and the on-board AC'97 audio. No need to fill up any PCI slots here. Just add a 128 MB stick of CL2 PC133 SDRAM, add a heatsink/fan, and it's good to go.
The attachment IMG_5871.jpg is no longer available
Reply 1 of 26, by Katmai500
Specs:
ASUS TMA-PL Socket 370S
Intel Celeron "Timna" 667 MHz
128 MB PC133 SDRAM CL2
Intel "Timna" integrated graphics
Crystal AC'97 integrated audio
DVD/CD-RW drive
Sinitech SD-IDE adapter with 32 GB SanDisk SD card
AOpen H500A ATX case
AOpen 350W ATX PSU
The attachment IMG_5872.jpg is no longer available
Boot up and Windows 98 SE installation:
The attachment IMG_5770a.jpg is no longer available
The attachment IMG_5775.jpg is no longer available
Installing Windows 98 had one major hurdle: graphics drivers for the Timna integrated graphics. I was able to easily find ICH2 drivers for the other chipset functions, and integrated audio drivers for another board, but the Timna graphics drivers were a challenge. Thankfully I was able to track down a single old FTP site with some BETA ASUS drivers that had the pre-release Timna graphics driver installer for Windows 98. (I also found one for NT 4.0 and 2000).
The attachment IMG_5777.jpg is no longer available
Windows 98 SE installed with all drivers working! The CPU is recognized as Family 6 Model 9. This model number was re-used for Pentium M Banias after Timna was cancelled. Interestingly, the team that developed Banias also worked on Timna.
The attachment Windows Info.jpg is no longer available
Reply 2 of 26, by Katmai500
Benchmarks:
3DMark99
2140 3DMarks
8900 CPU 3DMarks
The attachment 3DMark99.jpg is no longer available
The attachment IQ08I_3DMark99.jpg is no longer available
3DMark2000
888 3DMarks
The attachment 3DMark2000.jpg is no longer available
The attachment 3DMark2000 Details.jpg is no longer available
The attachment IQ08I_3DMark2000.jpg is no longer available
Reply 3 of 26, by Katmai500
3DMark2001SE
478 3DMarks
The attachment 3DMark2001SE Details.jpg is no longer available
The attachment IQ01I_3DMark2001SE.jpg is no longer available
The attachment IQ03I_3DMark2001SE.jpg is no longer available
SisSoft Sandra 99
The attachment Sandra CPU.jpg is no longer available
The attachment Sandra Memory.jpg is no longer available
Memory performance is pretty terrible as expected due to the Memory Translator Hub (MTH).
Reply 4 of 26, by Katmai500
Quake III Arena
Time Demo 1: 32.2 fps at Normal settings
The attachment Quake III Settings.jpg is no longer available
The attachment Quake III Result.jpg is no longer available
Summary:
This was really just a fun experiment with some rare cool hardware I came across. I've had the Timna CPU for many years, but only recently found a compatible motherboard. Performance is expectedly terrible, but it's a really rare and cool way to get miserable performance.
The attachment IMG_5563.jpg is no longer available
Reply 5 of 26, by Katmai500
UPDATE: I installed Windows XP and can confirm that it is compatible with the Windows 2000 Timna Graphics drivers
Details:
The driver installer crashes under XP, even with Windows 2000 compatibility set. Trying to do an automatic installation through device manager by specifying the INF also results in a compatibility error. However, if you use the "choose driver myself option" and force it to install the Windows 2000 driver, it works totally fine with XP.
The attachment Win XP Timna Info.jpg is no longer available
The attachment Device Manager XP Timna.jpg is no longer available
Benchmarks:
3DMark2001SE
507 3DMarks
The attachment 3DMark2001 SE.jpg is no longer available
Quake III Arena
Time Demo 1: 23.5 fps at Normal settings
It's very interesting that 3DMark2001SE scored slightly better in XP than on 98, but Quake III ran ~27% slower.
Reply 6 of 26, by Nexxen
I waited for a full review since it was cancelled.
This is what I call "tying up loose ends" 🤣
I can't wait for more.
Good job!!!!!!!
edit: TBH I'm happy they ditched it for Banias.
PC#1 Pentium 233 MMX - 98SE
PC#2 PIII-1Ghz - 98SE/W2K
- Bare metal ist krieg.
Reply 7 of 26, by BitWrangler
Wow, I hadn't heard of this thing ever. Doesn't seem way out of line for a 667 celeron though.
Last time I benched 3DM2k1 with an i810 chipset and celeron, the i752 graphics drivers I could find seemed to be a cheat version, 3DM dropped frames like crazy and score was around 1,500 liarmarks. Mistrusted all 2000-2010 intel graphics scores since. So looks like you got a driver that was "un optimised" i.e. actually tried to draw the frames. Some say that renaming the 3DMark executable foils some of the driver cheats but never tried it on intel specifically.
Reply 8 of 26, by Gmlb256
Very interesting to see the Timna in action! 😁
Reply 9 of 26, by Disruptor
Can we have some CPU-Z & GPU-Z screenshots please?
Can you upload the picture to cpu-world.com please?
https://www.cpu-world.com/sspec/QV/QV18.html
As this seems to be first Timna with specs then, you may also use their CPUID submit tool to create a new entry to their database:
https://www.cpu-world.com/Download/CPU_identification.html
Reply 10 of 26, by luk1999
Does it have unlocked multiplier? Have you tried to overclock this Celeron?
P4 3.4E, P4C800-E Dlx, 1 GB, X800 PRO 256 MB, SB Audigy, XP SP2
A1.4, A7V133, 512 MB, R8500LE, FM801, ME
P3 600, AX6BC, 128 MB, GF2 PRO 64 MB, ALS100+, 98SE
K6-2/300, MS5149, 64 MB, Virge 4 MB, V1 4MB, ESS1868, 95 OSR2
Reply 11 of 26, by marxveix
I did not know nothing about Timna before. How many Timna Celeron cpu-s are out there or where to get one?
From Socket370 Celerons i am missing only Intel Celeron 533A, all others i probably have in my cpu collection.
Best ATi Rage3 drivers for 3DCIF / Direct3D / OpenGL / GLUT / DVD : ATi RagePro drivers and software
33+MiniGL / OpenGL Win 9x dll files for all ATi-Rage3 based cards : ATi RagePro OpenGL files
Reply 12 of 26, by pentiumspeed
There was another rambus motherboard without MTH chipset. This one was on Aanadtech guess the motherboard thing, several years ago, had one southbridge with this socket.
Cheers,
Great Northern aka Canada.
Reply 13 of 26, by Katmai500
Disruptor wrote on 2023-11-03, 20:18:
Can we have some CPU-Z & GPU-Z screenshots please? […]
Every version of CPU-Z starting with 1.40 results in a VXD related BSOD. Older versions do work, but don't report correctly or very much info. Here's a screenshot from 1.39. No surprise that it's reported as a Pentium M Banias since that's the CPU which re-used the family and model originally allocated to Timna. Older versions report it as Intel P6.
The attachment CPUZ_Timna.jpg is no longer available
Fortunately, wcpuid works very well and reports lots of useful information:
The CPU clock speed, bus speed, multiplier, and cache info here are all correct. Timna uses a 133 MHz bus rather than the 66 MHz of a standard Celeron, and it has 128 KB of L2 cache. Stepping 2 makes sense since this QV18 is a A2 stepping of the Timna core. I have a 600 MHz QQ30 Timna which should be Stepping A1, but I have not tried to boot it yet. That CPU has a couple of slightly bent pins so I opted for the QV18 first. The socket info is incorrect, but likely related to Banias re-using the Family and Model allocated to Timna.
The attachment wcpuid_Timna_1.jpg is no longer available
Detailed cache information. I assume this matches a typical Coppermine Celeron, but need to confirm.
The attachment wcpuid_Timna_2.jpg is no longer available
Chipset info
The attachment wcpuid_Timna_3.jpg is no longer available
Motherboard/BIOS info
The attachment wcpuid_Timna_4.jpg is no longer available
I'll try running the tool after I get this Timna machine working on the internet. For now I posted the wcpuid image to the QV18 page. If I run QQ30ES I'll do the same for it.
GPU-Z is a no-go on Windows 98. I'll install Windows 2000 next and try out GPU-Z soon.
Reply 14 of 26, by Katmai500
luk1999 wrote on 2023-11-03, 20:29:
It does have an unlocked multiplier. The board would allow me to run it at 5.5X for 733 MHz, but I have not tried it yet. I can also increase the voltage, but do not want to take that risk. The stock voltage is 2.05 V. Quite a bit higher than a normal Coppermine core, likely due to the integrated graphics and memory controller. The board allows for up to 2.40 V.
marxveix wrote on 2023-11-03, 20:49:
I'm not sure how many are out there. They are Engineering Sample (ES) or Qualification Sample (QS) CPUs and were never released to the public, so they are pretty rare. A few have sold on CPU-World in the last 15 years and some others on eBay. I got mine over the years just knowing what to look for (unique markings on the CPU, unique pin-out), lots of checking of auction photos, and waiting for one to pop up.
pentiumspeed wrote on 2023-11-03, 23:45:
Cheers,
That was the original plan before RDRAM prices stayed high. A bunch of old Anandtech articles mention Timna motherboards shown at IDF or Computex, but all of the images are missing. Do you have a link to that article?
Reply 15 of 26, by Jasin Natael
Never heard of this thing.
This is really cool.
I wonder what what it would do with a discreet GPU, seems like the 133MHZ FSB would give it a serious leg up.
But then again the memory performance would be a drawback.
Reply 16 of 26, by H3nrik V!
Jasin Natael wrote on 2023-11-07, 15:24:
Never heard of this thing. This is really cool. I wonder what what it would do with a discreet GPU, seems like the 133MHZ FSB w […]
Yeah, a proper RDRAM boards would probably unleash some performance on the memory side ...
Reply 17 of 26, by wirerogue
definitely deserves a "never obsolete" sticker.
Reply 18 of 26, by Standard Def Steve
Just look at the og Xbox. It had a Coppermine Celeron w/ FSB133 and a GeForce 3.5.
Course, the Xbox CPU didn't have an IMC, but I'm guessing the external nvidia controller was even better.
"A little sign-in here, a touch of WiFi there..."
Reply 19 of 26, by Jasin Natael
Standard Def Steve wrote on 2023-11-07, 17:21:
Yeah, that's a good point. Would probably be similar. It's a shame there weren't more boards available with AGP. But honestly, it's just cool as it is.
