Reply 220 of 247, by Irinikus
- Oldbie
Seeing that I've been messing around with this machine a bit this weekend, a carried out another 3DMark Vantage test with the GTX 690 fitted and SLI enabled and got the following result:
Notice how well this system's currently doing compared to the theoretical maximum output of the 8800 GTX, which I'll use as the base comparison for all future GPU upgrades as it's just one year more modern than the motherboard and CPU's in this system and it was the fastest GPU around in its time!
The 690's performance vs that of the 8800 has basically doubled with the second GPU enabled! So with the TITAN X, and then maybe the RTX 3090 ti fitted, this machine may actually perform pretty well, all considered!!! As you seem to be getting decent scaling here! 😀
I've now also managed to install: Unreal, Soldier of Fortune and Half Life which all obviously run very well. (I haven't been able to get my Orange Box DVD up and running on the system as yet, as it doesn't seem to work with the latest version of Steam!!!)
I also tested out YouTube last night, and it runs perfectly on this system!!! (It's great to have a semi-vintage machine that you can effectively use on the web!)
