First post, by Susanin79
Greetings,
Recently bought nice Olivetti M290-20 with the late 286 motherboard. But this PC came to me without the HDD. I was unable to find a proper documentation for the exact model, and the documentation for similar models didn't get the clear answer.
It is no doubts that model can support only 40, 85 or 120 MB IDE hard drives (as there is only one possible choices in the BIOS).
The manual for the M290-25 model has this data (BIOS 2.01):
40MB - 980Cyl 5H 17S (W.D. AC 140, QUANTUM LPS 52 AT, CONNER CP 3044 or CP 3046F, QUANTUM ELS42 AT )
85MB - 977Cyl 10H 17S (W.D. CAVIAR AC 280, CONNER CP 30084E, QUANTUM ELS85 AT)
120MB - 762Cyl 8H 39S (W.D. AC-2120, CONNER CP 30126, QUANTUM ELS127 AT)
The manual for the M290-30 model has this data (BIOS 2.01):
40MB - 1219Cyl 2H 512S (Quantum LPS 53 AT, CONNER CP3046, W.D. AC 140)
120MB - 1524Cyl 4H 512S (W.D. AC-2120, CONNER CP 30126)
May be somebody have the same machine with the HDD installed and can share the model of that HDD installed?
Here is the dump of BIOS installed on my PC (version 3.07)
Thank you!
Reply 1 of 9, by Grzyb
Try SpeedStor 6.5 - it should list the HDD parameters table in ROM BIOS...
The attachment romtypes.png is no longer available
Another software worth trying is Checkit Pro.
Reply 2 of 9, by Susanin79
Grzyb wrote on 2023-11-02, 15:49:
There is no issues to find HDD matching C/H/S parameters, the problem is that I'm not sure that those HDD from list above will work with my model. As you see that the list of supported HDD from M290-25 is not equal to the M290-30, so in my case there may be another variants.
So, it would be better to find somebody with the same PC and ask what HDD is installed.
Reply 3 of 9, by Grzyb
FWIW, just saw M290-20 listed for sale, with Conner CP3000.
But seriously, aren't all disks with geometry matching the list in ROM BIOS supposed to work?
Is there anything special about those Olivetti machines that makes them pickier than other PCs?
Reply 4 of 9, by Susanin79
Grzyb wrote on 2023-11-02, 20:59:
Thank you, not so big, but will be enough for this PC
This geometry details were given for the another model and may not work for the M290-20.
No, I have couple of HDDs matching sizes and all of them didn't work on this Olivetti. There is no options to set the geometry in the BIOS
Reply 5 of 9, by Susanin79
Was able to find application that can read BIOS and display all supported types. And those settings are slightly different from the M290-25 manual.
Here it is, put it there for the history purposes 😀 Now it will be easier to find proper drive.
Type 1: 968 Cyl 5H 17S
Type 2: 977 Cyl 10H 17S
Type 3: 762Cyl 8H 39S
Type 4: 750Cyl 8H 17 S
Reply 6 of 9, by Grzyb
Susanin79 wrote on 2023-11-05, 14:53:
But have you tried SpeedStor or Checkit Pro?
I want to know if that "Hard Disk Tech Specs" is any better than the above...
Reply 7 of 9, by Susanin79
Beg my pardon, didn't know that SpeedStor can read the standard types from BIOS, as I always use a custom type. It was so easy 😀 And yes, SS shows the same table.
And for the Checkit Pro, I found 2 installation floppies, but I can not install it without the HDD.
Reply 8 of 9, by Grzyb
So I tried the three programs on my 486...
The attachment CKP111.png is no longer available
The attachment HDTS20G.png is no longer available
The attachment SS65.png is no longer available
Checkit Pro 1.11 lists some entries as "Extended or Invalid", while the other two can't see any problem with them...
Anyway, that Olivetti BIOS is really limited - only 4 predefined types.
Even the earliest IBM AT BIOS (01/10/84) supports 14 types.
Reply 9 of 9, by Yrouel
I looked at the BIOS dump for the Olivetti and the HDD table starts at 0x1E401:
Type1: C803 05 000000000000000000 C803 11 00
Type 2: D103 0A 000000000000000000 D103 11 00
Type 3: FA02 08 000000000000000000 FA02 27 00
Type 4: EE02 08 000000000000000000 EE02 11 00
Using Type 1 as example:
968 Cylinders -> 0x03C8 so C803
5 Heads -> 0x05
17 Sectors -> 0x11
Should be able to replace one of those with the parameters of the disk you want, my suggestion is to use a CF card instead of an hdd.
You'll likely need to adjust the checksum of the binary but I can't find where it is, I thought it would be the last byte but something isn't adding up (no pun intended), the checksum of the whole document is not 00 so perhaps check if the dump has been made correctly or maybe it's a different algorithm and someone else could chime on this hopefully
