Voodoo 3 2000 Artifacts and noisy video.
Reply 41 of 51, by Zerthimon
Yeah, these and the others (i counted 7 ?, same type) all over the board.
Edit: Before you recap the card, try running it with another mobo.
Reply 42 of 51, by _StIwY_
Zerthimon wrote on 2023-10-16, 12:21:
I have a news....i tried the card on another PC with WIndows 7 and........no noisy images anymore....... °L_°
I was sure the card was broken, because i never seen such a problem before. I'll keep you updated, i'm talking with a guy which should be able to explain / fix the thing.
Reply 43 of 51, by SaxxonPike
I understand that this thread is a few months old, but I have some new and relevant information to add.
I experienced this issue with multiple later Voodoo cards on my Athlon-XP machine, using the KT133A chipset. Today, I read through the datasheet and discovered this PCI register:
Device 1 Offset 40 - CPU-to-AGP Flow Control 1 (00h)RW
7 CPU-AGP Post Write
With my 5500, there is no replacement BIOS that I have found to solve the issue. However! By using PCISET I was able to disable this register:
PCISET 8305 1106 40 10000000 00000000
And now there is no flickering on the 5500 in the Duke3D title screen. Something to try if you don't fancy flashing a BIOS.
Sound device guides:
Sound Blaster
Aztech
OPL3-SA
Reply 44 of 51, by _StIwY_
Hello, sorry for the late reply. The problem was.....my damn LCD monitor. For some reasons, he might not "digest" the signal properly, and made me think the problem was elsewhere! It's already happened with other video cards too
Reply 45 of 51, by d909
SaxxonPike wrote on 2024-04-05, 03:28:
I understand that this thread is a few months old, but I have some new and relevant information to add. […]
This worked for me. Same setup as you. Thanks.
Reply 46 of 51, by nvllsvm
I had issues with my Voodoo 5500 (PCI) on my Abit AV8 (K8T800 Pro) w/ AMD FX-60. Disabling PCI post writes did fix the issue, but resulted in poor performance - particularly noticeable in 3D titles like Midtown Madness 2 and Unreal Tournament. I confirmed this with 3dmark99.
However - keeping post writes enabled, but underclocking my CPU to 1.3ghz also eliminates the artifacts I was seeing (eg. the menus in Unreal) without such a drastic hit to performance.
The attachment 3dmark99.jpg is no longer available
fwiw - these commands enable/disable PCI1 Post Writes on my Abit AV8 (K8T800 Pro):
Disable PCI1 Post Writes
PCISET.EXE 7282 1106 70 10000000 00000000
Enable PCI1 Post Writes
PCISET.EXE 7282 1106 70 10000000 10000000
Reply 47 of 51, by nvllsvm
nvllsvm wrote on 2024-10-03, 19:43:
I had issues with my Voodoo 5500 (PCI) on my Abit AV8 (K8T800 Pro) w/ AMD FX-60. Disabling PCI post writes did fix the issue, bu […]
After some further testing, underclocking does not resolve the issue in all games. Testing was done at 800x600x16
What it fixes
  • Blood 2
  • Midtown Madness 2
  • Unreal
  • Unreal Tournament
What still has artifacts
  • Quake 2
  • Sin
Reply 48 of 51, by PcBytes
bloodem wrote on 2023-05-18, 09:27:
DesktopDynamite wrote on 2023-05-18, 05:14:
Update: […]
Update:
So, I have now downgraded the system to a PII 400Mhz, clocked at 266Mhz in BIOS. Also I have installed single stick of 64MB RAM clocked as 100Mhz [instead of 512MB of 133Mhz]
Currently I did remove the Nvidia AGP card completely and the USB 2.0 PCI card as well, moved the Voodoo 3 on to the first PCI slot.
Testing done on Windows98 and also restarting in MS-DOS, no artifacts anymore, I am guessing the RAM speed from 133Mhz to 100Mhz did the trick here, as at first, the artifacts remained with PII clocked down to 266Mhz and with 256MB at 133Mhz.
I will now try again with the PIII, but this time leaving it with 64MB RAM.
Testing will also be done under pure ms-dos 6.22 setup...
Your problems (and the problems described in this thread) can be permanently solved by flashing one of the newer Voodoo 3 BIOS versions (if you are comfortable with doing it). After that, the card will work fine with any CPU speed, including a very fast Athon XP (and there will be no need to change any motherboard BIOS settings).
Be careful, though, it's very easy to brick the card when flashing it (in which case, you will need an additional card to try and recover it - ask me how I know 😁 ). In your case, since you have a PCI Voodoo 3, you'd need an additional AGP card for the (potential) recovery process.
The BIOS flashing part might be YMMV. I, at least, couldn't revive a V3 3000 with the last BIOS - it did POST and output video but there was heavy artefacting that rendered the card unusable.
Reply 49 of 51, by OpenRift
Hey @bloodem, is there any chance we could see a fix for the artifacting on Voodoo3 1000 (aka Velocity 100) AGP cards as well?
Reply 50 of 51, by bloodem
OpenRift wrote on 2025-03-12, 01:59:
Unfortunately, I don't have that card (well, I do, but it's in a very bad state with the Voodoo chip currently removed and some solder pads that need fixing).
It should be mentioned, though, that Voodoo 3 1000 is not the same as the Velocity 100, they are two different cards.
2 x PLCC-68 / 4 x PGA132 / 5 x Skt 3 / 1 x Skt 4 / 9 x Skt 7 / 12 x SS7 / 1 x Skt 8 / 21 x Slot 1 / 8 x Slot A
Current PC: Ryzen 7 9800X3D
Backup: Ryzen 7 5800X3D
Reply 51 of 51, by OpenRift
bloodem wrote on 2025-03-22, 09:40:
What's the difference between the cards?
