First post, by haker120
I have finally build PC (I mean I had no case for so long) with following:
Motherboard: DFI CS62-TC
RAM: 512MB in two sticks
CPU: Intel Pentium 3 1.4GHz
GPU1: GeForce 4 4600 Ti
GPU2: Voodoo 2 in SLI 12MB
Sound Card: Audigy 2 ZS SB0350
I barely installed sound card drivers that don't wipe themselves after reboot. Is there a driver for DOS games? To have at least basic sound and music?
Reply 2 of 8, by Joseph_Joestar
Pickle wrote on 2023-11-10, 22:01:
i use this even though it targets live cards. the last step add the dos files
Re: Using Audigy drivers with a Sound Blaster Live 5.1
That won't work for Audigy 2 / ZS cards since they need a few extra steps.
To the OP, the Audigy 2 ZS has no official DOS support. However, you can force it to use the DOS driver pack from the Audigy 1 installation CD, albeit in a somewhat convoluted way. I have a guide for that, though how well that works might depend on the rest of your hardware. See here: Guide: Installing Windows 9x and DOS drivers on Audigy cards (version 3.1)
Reply 3 of 8, by haker120
As of now VXD drivers don't work, device is working in device manager but apps say 'no supported hardware found'.
Reply 4 of 8, by Joseph_Joestar
haker120 wrote on 2023-11-11, 13:49:
This can happen with some OEM cards manufactured by Dell. Those might need specific drivers from Dell's website to work correctly. If your Audigy 2 ZS has three white stickers on the back side, it's likely a Dell card.
Anyway, a clean install of Win98SE is recommended before installing Audigy 2 ZS drivers. If you haven't tried that already, reinstall Windows and then follow my guide linked above to see if that helps.
Reply 5 of 8, by haker120
I did, on fresh Win98SE installation all works in windows and DOS (running in window mode). Now I wonder if I should instal Patch93's SC-55 soundfonts but as of now I am really content. Thanks @Joseph_Joestar! 😁
Reply 6 of 8, by Pickle
Joseph_Joestar wrote on 2023-11-10, 22:25:
Do you mean just the dos support? I did have one pc with a audigy 2 and the window dos devices didnt set up right. I assumed it was a resource issue and i was using a real sb16 so i didnt bother.
Reply 7 of 8, by Joseph_Joestar
Pickle wrote on 2023-11-11, 16:35:
Yes, the DOS support needs extra steps for Audigy 2 and ZS cards.
Reply 8 of 8, by Joseph_Joestar
haker120 wrote on 2023-11-11, 16:18:
You're welcome! 😀
