Reply 50880 of 57034, by bearking
Trashbytes wrote on 2023-11-12, 08:29:Saw this odd little Socket 370 CPU on the bay and decided to grab it, at its core its a VIA C3 Samuel 2 running at 533 but normally its a BGA chip for embedded systems. This one has been mounted to a interposer and will run in any socket 370 board that supports the VIA C3, The seller had some info about it and only a few thousand were ever made for socket 370.
Normally I wouldn't bother with a VIA C3 but I do have a baby AT socket 370 board that supports the C3 and was thinking this little chip would make for an interesting low power DOS/Windows box, this CPU operates between 2.8 to 5 watts of power so with a Voodoo3 and a SSD it would be pretty much silent. (I have a passive MX400 that would also be a good fit)
Wow, that VIA chip is a nice collectable! I'm looking forward to see a system around it...
