Reply 60 of 644, by BEEN_Nath_58
myne wrote on 2023-11-16, 08:08:
How's this one?
Cheers! Works great
Reply 61 of 644, by myne
Does the 50fps work in DX?
You might want to tell your mate on the dxwnd forums that the installer can probably be modded for the pentium edition.
I might have a look at it later, but I guess I didn't really see the point when Titanium was the last and most complete release.
I built:
Reply 62 of 644, by BEEN_Nath_58
myne wrote on 2023-11-17, 00:31:
According to DxWnd framerate overlay - yes. Didn't Direct3D mode work for you?
About the Pentium edition, I restarted on it - he is open to remove the sdb installation dependency (integrating IgnoreScheduler) + the game needs EmulateHeap to be stable in mission exit and enter and I would want to have a subset of it (on Win11 22H2+ it could cause issue)
Reply 63 of 644, by myne
Send them the attached.
It installs the pentium edition.
If you can get it working, then we can bundle that too.
I built:
Reply 64 of 644, by BEEN_Nath_58
myne wrote on 2023-11-17, 06:07:
Okay but why did you rename MECH2.EXE to mw2tit.exe for this?
Reply 65 of 644, by myne
I was attempting to get it to run with your patches
Just change that line (250)
I built:
Reply 66 of 644, by BEEN_Nath_58
myne wrote on 2023-11-17, 07:34:
There is still some things wrong.
First it didn't copy the DPLAY.DLL (I mentioned to copy from CD on my original post, but copying the one from SysWOW64 seems to be better in general).
I copied it, now it displays yet another error. It was caused by a file, that after a proper installation appears in another form. I attached it in attachment, but I can't tell if its specific to my machine or works on yours too. You can try it yourself.
Reply 67 of 644, by myne
I didn't copy dplay. I just copied the stock intaller's output.
Didn't think that far ahead.
C:\>fc "C:\Games\MW2-95 31st Century Combat\MW2PRM.CFG" "c:\Program Files\Activision\Mech2 - Copy\mw2prm.cfg"
Comparing files C:\GAMES\MW2-95 31ST CENTURY COMBAT\MW2PRM.CFG and C:\PROGRAM FILES\ACTIVISION\MECH2 - COPY\MW2PRM.CFG
FC: no differences encountered
Haven't run it, but the files are the same.
I built:
Reply 68 of 644, by BEEN_Nath_58
myne wrote on 2023-11-17, 09:58:
I didn't copy dplay. I just copied the stock intaller's output. Didn't think that far ahead. […]
You can try opening the files with a Hex editor. I think you'll see a difference there. O tried to copy the cd file to the folder and the mission doesn't run, but with this file they run
Reply 69 of 644, by myne
fc is a windows command dating back to early DOS.
It compares 2 files.
If it says there are no differences, there are no differences.
I built:
Reply 70 of 644, by BEEN_Nath_58
myne wrote on 2023-11-17, 10:12:
Not really. The first byte is even different, then check Line 108.
(Left is the one from installation, right one from CD)
file.php?mode=view&id=178660
Reply 71 of 644, by myne
Your own guide literally says to copy the files directly from the CD.
Which you implied works.
How exactly are you changing the first byte of that file in that process?
I built:
Reply 72 of 644, by BEEN_Nath_58
myne wrote on 2023-11-17, 19:41:
I noticed that too. In fact this works in Windows 10. I have to see what happened in Windows 11 that stops this from working.
Reply 73 of 644, by myne
Works properly.
Only annoying thing is I can't figure out how to get CDaudio.
Nothing I tried worked.
The attachment mercsfinish.png is no longer available
I built:
Reply 75 of 644, by myne
Yeah mercs.
I tried "just read it from the cd", emulate, ripping into the music folder
Nothing.
I built:
Reply 76 of 644, by BEEN_Nath_58
myne wrote on 2023-11-18, 08:50:
Yeah mercs.
Nothing.
I can get the CD audio working here. I will need specifics, which mission type, which contract...
Reply 77 of 644, by myne
What settings do you use?
It never worked. On any mission. Not once beginning to end.
I built:
Reply 78 of 644, by BEEN_Nath_58
myne wrote on 2023-11-18, 09:23:
Check in Instant action. Run DxWnd and keep View -> CD player monitor open and check for this (you can see the track16 is being played and the CD volume mixer is at 100%, that can be changed from in-game):
Reply 79 of 644, by myne
Nevermind. Working.
It MUST be the first CD by letter.
I built:
