shandavid wrote on 2023-11-19, 09:52:
Can you hear their difference? I can,  to my ears, SC8820 > SC VA > SC8850, JV-1080 hardware >  software
The differences in sound are the same: comfort, smoothness, better timbre etc
Have you considered that any differences you perceive may be purely psychological?
Human perception is highly malleable, even if there is no objective difference in the source. It's why people think more expensive wine better than cheap wine, even if it's the exact same wine (see article: How Your Brain Tricks You Into Thinking More Expensive Wine Tastes Better)
If there really were an objective difference in sound quality, then the two ways to demonstrate this would be:
1) Object waveform measures via something like an oscilloscope
2) Blind tests
You may think one sounds better than the other, but without a propr test you won't really know if there any real difference.
From the sample you posted, I don't hear a difference. And this is after careful listening on highly quality speakers. FWIW, I also listening to your previous comparison when you modded your MU90 by changing capacitors and I  didn't hear a different there either.
I think you've convinced yourself you're making the sound better, even if there is no change in the actual sound.
