dgVodooo 2.8.x and related WIP versions
Reply 60 of 201, by Dege
lowenz wrote on 2023-11-14, 20:23:
Very minor (but interesting) HUD problem with UT99 in DDRAW updated with this: https://github.com/OldUnreal/UnrealTournament … s […]
Very minor (but interesting) HUD problem with UT99 in DDRAW updated with this: https://github.com/OldUnreal/UnrealTournament … s/tag/v469d-rc4
Forcing the AF 16x in dgVoodoo2 (you can see some line artifacts with the same colour of the energy belt, every time with a slighly different lenght and position in the same HUD zone):
No AF in dgVoodoo2:
I guess it depends on what texture coordinates are used to draw those HUD quads. Different sampling mode can behave slightly different ways. 😐
Reply 61 of 201, by Dege
For the time being, I release the current state as a new version. I'll release patch versions if something regression is detected/reported.
v2.82
  • D3D/8/9 improvements and fixes
    * Hardware vertex buffers in D3D6/7
    * Improving the PS shader code generator to handle D3D colorkeyed textures (also fixing the D3D12 LOD-problem)
    * Overhauling the general pipeline code and the capabilities of the FF pipeline
    * Adding support for the reference device in D3D8/9 (Operation Blockade)
    * Improved DD/D3D API tracing, some bugfixes/changes and additions in the DX debug layer
    * Clipping / vertex layout / fog bugfixes (Extreme Paintbrawl 4, Max Payne, Off Road Arena)
    * D3D9 fixes (fr-054 Polar, Crush, Nitro Stunt Racing, Trackmania Sunrise Extreme)
    * Fixing the "clipped cursor" issue when exiting D3D8/9
    * Improving DDraw compatibility (Legion Gold)
    * Improving DirectShow compatibility (Project Eden)
    * Forcing texture filtering did not work properly in D3D, fixed
    * Fixing a regression bug in DDraw compression Blt (Eurofighter Typhoon)
    * Fixing a windowed Blt bug in DDraw (my own test app)
    * Fixing a regression crash in D3D12 UP Draw (Tomb Raider 5)
    * A bugfix in the cpu code generator
    * A bugfix in the blitter shader code generator
    * Auto mipmap-generation (changing option DirectX\DisableMipmapping to DirectX\Mipmapping)
  • Glide fixes
    * Fixing a rendering incompatibility (Outlaws)
    * Fixing a freeze/crash bug in Glide D3D12 dynamic resolution changing
  • General improvements
    * Changing/fixing a lot of things in the source using a code analyzer
    * Doubling the tooltip appearance time in the Cpl
    * Implementing loader lock detection for all (missing) platforms (x64, arm64/ec)
    * Internal changes and code refactoring under the hood
http://dege.fw.hu/dgVoodoo/bin/dgVoodoo2_82.zip
http://dege.fw.hu/dgVoodoo/bin/dgVoodoo2_82_dbg.zip
Edit: I fixed a bug and reuploaded the .zip's.
Reply 62 of 201, by lowenz
Just purchased an Intel Arc A380, will test dgVoodoo2 on Intel HW 😁
Reply 63 of 201, by KingSyphilis
Hi Dege,
Any chance you could maintain a persistent URL to the latest release? I'd like to utilise such a URL in game installer scripts. There's a sort of workable solution described here: https://github.com/ogham/exa/issues/668
Basically: Query the version tag of the latest release (e.g. "v2.82"), transform it ($VER = "2_82"), then generate the relevant URL in the following form: "https://github.com/dege-diosg/dgVoodoo2/relea … gVoodoo$VER.zip"
Thanks for your consideration
Reply 64 of 201, by Dege
KingSyphilis wrote on 2023-11-23, 06:01:
Hi Dege, […]
Hi Dege,
I made a redirect to the latest github release through my site:
http://dege.fw.hu/dgVoodoo2/dgVoodoo2_latest.zip
I don't know how to place the redirection on github itself though, but that'd be the best.
Reply 65 of 201, by rico001
Should dgvoodoo be used with mesa 3d for windows?... I can't get the mesainjector to work on: https://fdossena.com/?p=mesa/injector_build.frag to inject opengl.dll (Wine3D/mesa mesa3d-23.2.1-release-mingw ) fun project. using windows... thanks for the software.
Reply 66 of 201, by KingSyphilis
Dege wrote on 2023-11-27, 20:15:
I made a redirect to the latest github release through my site: […]
Hi Dege, […]
Hi Dege,
Perfect, thank you!!
Edit: Please note that your SSL certificate isn't configured properly; for my purposes, I'm forced to fall back to HTTP only.
Reply 67 of 201, by Dege
A released a new patch version with an improvement/fix that I should have include in the latest release:
v2.82.1
  • Remapped D3D/8/9 lights to reduce the number of FF shader variants (UT2004, RavenShield, games using FF vertex pipeline)
  • Fixing the 2D blitter and 3D texturer to handle colorkeyed ARGB2101010 and ARGB16161616 format textures properly
  • Compiler toolset upgrade
http://dege.fw.hu/dgVoodoo2/bin/dgVoodoo2_82_1.zip
http://dege.fw.hu/dgVoodoo2/bin/dgVoodoo2_82_1_dbg.zip
Edit: links fixed
Reply 68 of 201, by Dege
KingSyphilis wrote on 2023-11-28, 05:11:
Hi Dege, […]
Hi Dege,
Well, yes... I'm not an expert in that at all... can I configure it or is it up to the host provider?
Reply 69 of 201, by KingSyphilis
Dege wrote on 2023-11-28, 18:43:
It may depend on the plan you have with your provider. Though, I see that your domain name is currently utilising a certificate provided by Let's Encrypt (these are usually free), though it is only valid for sas.hu. Your hoster could probably set one up for your individual domain on your behalf. Also, take a look at: https://letsencrypt.org/getting-started/
Reply 70 of 201, by BEEN_Nath_58
Small question that I had: what does the d3dimm.dll do? I mean it's not xactly d3dim.dll probably, and many games that use d3d still run with ddraw.dll only, so what it is primarily?
Reply 71 of 201, by Deffnator
Dege wrote on 2023-11-28, 18:40:
A released a new patch version with an improvement/fix that I should have include in the latest release: […]
v2.82.1
http://dege.fw.hu/dgVoodoo/bin/dgVoodoo2_82_1.zip
http://dege.fw.hu/dgVoodoo/bin/dgVoodoo2_82_1_dbg.zip
dege, the links are dead
Also, can you please check with Destro at WCNews about Wing Commander 3 and the Kilrathi saga patches?
https://www.wcnews.com/chatzone/threads/wing- … d.30387/page-10
The latest versions started to give rainbow artifacts on the videos when increasing resolutions, the previous 2.8 wip 89_1 release had no artifacts at all
https://imgur.com/a/eiPbuAT
Reply 72 of 201, by Dreadmoth
Deffnator wrote on 2023-12-09, 14:03:
They're missing a "2":
Windows 10 64-bit | Intel Core i7-4770 @ 3.4GHz | MSI GeForce GTX 1070 Ti Titanium 8GB | Samsung S23A700D, 1920x1080@120Hz | Gigabyte GA-Z87-HD3 | Corsair Vengeance 16GB DDR3, 1866MHz @ 9-10-9-27 | Samsung 860 EVO 2TB
Reply 73 of 201, by Dege
KingSyphilis wrote on 2023-12-01, 03:06:
Thanks, I'm going to look into it!
Reply 75 of 201, by Dege
BEEN_Nath_58 wrote on 2023-12-06, 17:13:
D3DImm.dll contains the implementation of the 3D interfaces. DDraw.dll is ddraw only. The same architecture as with MS DD/D3D.
Reply 76 of 201, by Dege
I released a new patch version again, a minor update:
v2.82.2
  • Refactoring the FF ps code generator to produce a bit more optimal code
  • Fixing a lighting D3D incompatibility with MS D3D (Project I.G.I.)
  • Fixing a broken shader for D3D11 FL11.0 (Blood 2)
  • Adding Green Sardine/Cezanne AMD architectures to the D3D11 blacklist (device ID: 0x1638)
  • Fixing a bug in the blt shader code generator (Morrowind)
http://dege.fw.hu/dgVoodoo2/bin/dgVoodoo2_82_2.zip
http://dege.fw.hu/dgVoodoo2/bin/dgVoodoo2_82_2_dbg.zip
Edit: release updated and reuploaded on 2023.12.26
Reply 77 of 201, by Dege
I reuploaded 2.82.2 with a fix, updated the previous post.
Reply 78 of 201, by galeksandrp
Dege wrote on 2023-12-26, 18:50:
Hello Dege. Thank you for your awesome work! Question:
- Can WidescreenFixesPack redistribute dgVoodoo2 ?
1. WidescreenFixesPack is a collection of ASI runtime patches for legacy PC games making them widescreen-supported. dgVoodoo2 is used alongside Knight Rider and Splinter Cell patches. More about it: https://thirteenag.github.io/wfp#scpt
2. For years it downloaded dgVoodoo2 on first game start via HTTP from http://dege.freeweb.hu/dgVoodoo2/dgVoodoo2/ to avoid redistribution infringement http://dege.fw.hu/dgVoodoo2/ReadmeGeneral/#re … tributionrights.
3. But now entire modupdater subsystem including http(s) downloader is deprecated due to drastic changes in WidescreenFixesPack distribution scheme
so I would like to request permission to redistribute dgVoodoo2 with WidescreenFixesPack.
Discussion with WidescreenFixesPack authors : https://github.com/ThirteenAG/WidescreenFixesPack/pull/1496
Reply 79 of 201, by lowenz
Are you thirteenag? Hi man! 😁
